Revision: 14139
Revision: 14139
Author: klin@adobe.com
Date: 2010-02-11 16:36:39 -0800 (Thu, 11 Feb 2010)
Log Message:
Fix for Player classes not code hinting to framework FB projects. Changed all the $ tokens to use $ instead. While the compiler understands $, Flash Builder's code model does not.
No code changes.
QE notes: N/A
Doc notes: N/A
Bugs: None
Reviewer: Pete
Tests run: checkintests
Is noteworthy for integration: No
Modified Paths:
flex/sdk/trunk/frameworks/projects/airframework/.actionScriptProperties
flex/sdk/trunk/frameworks/projects/airspark/.actionScriptProperties
flex/sdk/trunk/frameworks/projects/flex/.actionScriptProperties
flex/sdk/trunk/frameworks/projects/framework/.actionScriptProperties
flex/sdk/trunk/frameworks/projects/osmf/.actionScriptProperties
flex/sdk/trunk/frameworks/projects/rpc/.actionScriptProperties
flex/sdk/trunk/frameworks/projects/spark/.actionScriptProperties
flex/sdk/trunk/frameworks/projects/sparkskins/.actionScriptProperties
flex/sdk/trunk/frameworks/projects/textLayout/.actionScriptProperties
flex/sdk/trunk/frameworks/projects/wireframe/.actionScriptProperties
