Hey Guys,
I created a process to fetch data from a table in my MYSQL database and its working fine. The output of this process is a list of String.
I wanted a list box in my form to get dynamic value from this process. I have binded my process output to the "Specify Item Vaules" of the List Box object in the form. But in the "Preview PDF" tab i am not getting the dynamic values getting listed in the listBox. I have attached the LCA file. Kindly help me resolve the issue.
Do I require Adobe Acrobat PRO Extended for this dynamic invocation. I have installed Adobe Reader alone.
Also I find that there is no service request when I manually invoke the button from the PDF. I used "Servic Capture Application" to check if there is a service request.
Total Likes
Preview PDF tab will not work if you only have Adobe Reader Installed. You must require Acrobat.
Or save your file and apply usage right in order to see the proper results.
Nith
Thank you Nith
Total Likes
