Can a link to a new page stay in the same window?
Feb 12, 2010 Feb 12, 2010
I have several presentations that flow from one to another via clickable links that I created in Powerpoint using the right-click "Hyperlink" feature.
Presenter recognizes these and implements them nicely, except it always opens a new window when the link is clicked.  I'd like everything to stay in the same window when a clickable link loads a new page or presentation.
Can this be done?
RW
Presenter
746
Mar 18, 2010 Mar 18, 2010
Did you ever find a solution?
No, not yet...
Mar 23, 2010 Mar 23, 2010
I think I found some solutions on another site -
http://www.connectusers.com/forums/cucbb/viewtopic.php?id=960 - read the bottom posts from 9-23-2009.  Looks like there are two possible solutions, though I have not tried either.  I am trying the Flash button approach (second suggestion) today.  Will let you know if it works, but sounds like it would.
Guest
I will be out of the office starting 22/03/2010 and will not return until
24/03/2010.
If your matter is urgent, then please contact Emma Dawson on ext. 15832.
I wanted to post an update that the Flash button solution worked beautifully.  I was able to create a single button template to use at the end of multiple presentations by passing in a URL variable to the imported flash object.  You can add the url variables that you want to get to the swf file embedded in the ppt by adding them to the /[your pres name]/data/viewer.xml file.  Just locate the slide that has the embedded content and you can then attach the url variables.
Of course, you can also just hard code the link in your Flash button file, but then you would need to create a new file/swf for every presentataion.
Hope this helps you.
Help resources
