1. Re: Additional HD Drive
Gyno-jiz Jan 14, 2010 1:11 PM (in response to Mark A Goodwin)Your Mac Pro will run two hard rives fine (as separate drives). You can set them up with a software RAID in the OS if you'd like. But probably separate will be fine for your needs.
2. Re: Additional HD Drive
Mark A Goodwin Jan 14, 2010 1:26 PM (in response to Gyno-jiz)Thanks JM!
So I guess the benefit of using raid would be to what?...String them both together to provide...faster usage? or greater capacity or what?
Not that it matters to me now that I know I can install the new HD. It's just that if it would be a benefit speed wise it may be worth considering. I mainly use the machine for Photoshop and obviously the faster I can get it to run the better.
Thank you again for taking the time to respond
Regards
Mark
3. Re: Additional HD Drive
Gyno-jiz Jan 14, 2010 2:04 PM (in response to Mark A Goodwin)Optimizing PS for speed:
http://kb2.adobe.com/cps/404/kb404440.html
I would say if you don't know why you need RAID, you don't need it.
You can read more about it here:
4. Re: Additional HD Drive
John Smith for example Jan 14, 2010 2:55 PM (in response to Gyno-jiz)Make a RAID 0 array with the disc utility. RAID 0 will give you more speed. Depending on your setup and work you may or may not feel the difference, but as it comes at no additional cost it would be silly not to do it unless you have a specific reason. If you choose not to use RAID, then at least put the Photoshop and the system scratch on different discs.
5. Re: Additional HD Drive
Mark A Goodwin Jan 14, 2010 3:00 PM (in response to John Smith for example)Many thanks chaps!
Good advice greatly appreciated
Mark
6. Re: Additional HD Drive
Lundberg02 Jan 14, 2010 4:31 PM (in response to Mark A Goodwin)Do you want speed, backup, or capacity?
You can get a La Cie 2 tB external with FW400 chaining, FW800, USB 2.0 and e SATA interfaces for 219 free ship from Tekserve, comes with everything cables, software, manual. If your computer has an eSATA port, you get all you want in one box. Speed, capacity, backup, RAID types, and onetouch app launch.
If backup is mission critical you need external anyway.
Use one internal for apps and one for scratch and data.
I believe RAID 0 from disk utility requires two identical drives.
7. Re: Additional HD Drive
Mark A Goodwin Feb 6, 2010 7:00 PM (in response to Lundberg02)Hi Chaps
I received such good advice from this post, I thought I would run this past you for your thoughts.
Bought an internal Samsung 1.5TB HD. Partitioned it so that I have 500GB for normal data storage and 1TB for Scratch and photo store. I also have the original Mac HD of 650GB running the applications and the system. Lastly I have a 500GB External running Time Machine.
I have 8GB of Ram and it's running Snow Leopard 10.6.2 with CS4.
I can't believe how slow it is. It slower than my previous G5, and it is freezing and crashing all the time. Especially in PS, I spent 6 hours on a job yesterday and just when I finished and tried to save I got the Beech Ball and that was it! Lost. I can try to flip from one screen that I am working on (say) and then go into Bridge to look for another pic and I can get the dreaded Beech ball and I am forced usually to shut the machine down. I cant even Opt + cmnd +esc to force quit, I have to literally shut it down at the power switch.
I am fed up with doing a PRAM start that doesn't help
I have gone through disk utils and checked for permissions, repairs etc and all is fine. The addittional ram was installed by Apple before I took delivery.
Does anyone have any suggestions please?
Regards
Mark
8. Re: Additional HD Drive
Lundberg02 Feb 8, 2010 3:24 PM (in response to Mark A Goodwin)RAM is not allocated properly, or you need to test for bad RAM. Your box should be faster than light.
9. Re: Additional HD Drive
Niles Ridgeman Feb 9, 2010 10:03 AM (in response to Lundberg02)Yah, I agree, something is up with you system. But check the ram allocation.
Multiple partitions on you new disk are just helpful for your own organization - won't help with scratch disk performance (it all goes down the same wires/controller).
10. Re: Additional HD Drive
Mark A Goodwin Feb 9, 2010 2:56 PM (in response to Niles Ridgeman)Interesting stuff. Thanks guys.
However, the up rated Ram from 4 to 8 was done by Apple at their store. How can I check if they have done things properly? Any suggestions on how the Ram should be allocated? And finally, is this something I can do myself?
Mark
11. Re: Additional HD Drive
Niles Ridgeman Feb 9, 2010 3:34 PM (in response to Mark A Goodwin)RAM allocation in photoshop. Preferences:Performance - theoretically should be around 70%, but you should read the stuff in the link above about optimizing performance.
12. Re: Additional HD Drive
Mark A Goodwin Feb 10, 2010 4:26 PM (in response to Niles Ridgeman)Many thanks Niles
I usually keep the ram for the scratch at around 70% although I understand if I have anything over 2GB I can go higher. I have 8GB but I am still keeping at between 70 and 80%.
I feel there is something seriously out of place. Whenever the machine 'sleeps' when I wake it, the partition which is the 'Data-Store' is always missing from the desktop. The main drive Mac HD is there, also the Scratch-Store is there as is Time Machine (External). I always have to shut the machine off at the power button! The alt+cmnd+esc does not work.
I have checked the all the disks and the partitions with disk Utilities, and repaired permissions etc and verified. I have run CleanMyMac, and today after subscribing to Mac Protection Plan, I ran the app they sent me which is ToolTech Deluxe, which appears to be able to locate any faults on the drives. All without any further success.
The only thing I haven't done as yet is check for a Graphics Card update.
Meanwhile the machine continues to run slow and crash for no apparent reason. Last night whilst I was working on a PS Photo file I suddenly got an error message telling me that Bridge had shut down!
I guess the next stage is to get is back to the supplier!
Thanks once again for your help
13. Re: Additional HD Drive
Niles Ridgeman Feb 11, 2010 11:07 PM (in response to Mark A Goodwin)Yikes. I don’t envy you all that.
That kind of system wide stuff (in my experience) is usually memory problems. Google "OSX memory testing" - I think “memtest” is good, but look around. I doubt it’s the disks, probably the ram.
I’d be inclined to make it Apple’s problem if you can’t figure it out. Apple care should cover you. Get them on the phone until they admit it has to come in.
Graphics cards (assuming they are apple supplied) don’t need updating (anything they need will come when you do regular updates). It’s not that.
Best of Luck!
14. Re: Additional HD Drive
Lundberg02 Feb 12, 2010 3:57 PM (in response to Niles Ridgeman)This statement makes no sense:
I usually keep the ram for the scratch at around 70% although I understand if I have anything over 2GB I can go higher. I have 8GB but I am still keeping at between 70 and 80%."
Allocate 3+ RAM to Photoshop. The system will use the rest of the 8gB. That's where your problem with speed is. Plus the fact that you don't understand memory.
Run fsck -fy if it still functions in SL.
Relaunch the Finder if a disk doesn't show up.
Repair permissions.
15. Re: Additional HD Drive
Mark A Goodwin Feb 12, 2010 4:24 PM (in response to Lundberg02)Run fsck -fy if it still functions in SL.
Repair permissions.
Wow! And you say my statement don't make sense.
OK. Adobe say that "you should use no more than 70% of your available ram for the scratch disk. Unless, you have more than 2GB! If you have more than this you can go up to 95%". I said that even though I have 8GB of Ram I am still only using between 70 and 80% max of this amount, therefore well below the recommended amount. Sorry if I didn't make myself clear.
- I have repaired disk permissions a number of times.
- Sorry I don't understand what you mean by 3+
- neither do I understand fsck-fy in SL (or are you swearing at me)?
As you may have guessed I am not THAT technical any skills that I may have lie in other areas.
But thank you for taking the time to respond!
17. Re: Additional HD Drive
Tai Lao Feb 12, 2010 7:22 PM (in response to Mark A Goodwin)Mark A Goodwin wrote:
… Adobe say that "you should use no more than 70% of your available ram for the scratch disk.
Really? Where do you think Adobe says that? I fear it would be a nonsensical utterance anyway. The scratch disk has nothing to do with RAM. RAM is not used for the scratch disk. Photoshop's scratch disk is created on a designated hard drive.
Wo Tai Lao Le
我太老了
18. Re: Additional HD Drive
Tai Lao Feb 12, 2010 7:26 PM (in response to Mark A Goodwin)As an example, I keep more than 300 GB on separate, dedicated internal hard drives just for Photoshop's scratch disk.
我太老了
19. Re: Additional HD Drive
Tai Lao Feb 12, 2010 7:31 PM (in response to Mark A Goodwin)Mark A Goodwin wrote:
…even though I have 8GB of Ram I am still only using between 70 and 80% max of this amount, therefore well below the recommended amount. Sorry if I didn't make myself clear.
Ah, that explains some things. Thank you.
The 70% to 80% you're setting in preferences means you are telling Photoshop to use no more than 80% of whatever memory may be available at any given time, after the OS and other running applications have taken what they need. That has absolutely nothing to do with "scratch".
Wo Tai Lao Le
我太老了
20. Re: Additional HD Drive
Mark A Goodwin Feb 13, 2010 5:48 AM (in response to Gyno-jiz)Thanks JM
That explains a lot.
Cheers
Mark
21. Re: Additional HD Drive
Mark A Goodwin Feb 13, 2010 5:53 AM (in response to Tai Lao)Thanks for the feedback Wo Tai Lao Le
My scratch disk has 1 TB of space. I was under the impression that I had to allocate an amount of Ram to that disk not excfeeding 70% of Ram that is available.
Please see attached screen grab of my Preferences panel.
Regards
Mark
Prefs Grab.tiff 135.6 K
22. Re: Additional HD Drive
John Joslin Feb 13, 2010 8:38 AM (in response to Mark A Goodwin)Mark A Goodwin wrote:
You don't allocated RAM (memory) to the Scratch Disk (Hard Drive).
They work together under Photoshop but are not related.
23. Re: Additional HD Drive
Junk Mailer Feb 13, 2010 10:58 AM (in response to Mark A Goodwin)I think you are confused about the difference between memory (RAM) and storage (disk space, as you would use for a scratch disk). Find an article on the web that teaches basic computer hardware components and I think you'll understand this better.
-JM
24. Re: Additional HD Drive
Mark A Goodwin Feb 13, 2010 3:55 PM (in response to Junk Mailer)Thanks JM. Can you explain to me please what is meant then by this view in Prefrences
Prefs Grab.jpg 64.4 K
25. Re: Additional HD Drive
Niles Ridgeman Feb 14, 2010 10:44 AM (in response to Mark A Goodwin)Okay, now we've got that out of our systems. Your prefs are fine. It's safe to say Ram allocation and scratch disks are not your problem.
Feel free to put them out of your mind.
So any luck with the RAM testing?
Still having the slow down and errors?
26. Re: Additional HD Drive
Mark A Goodwin Feb 14, 2010 1:48 PM (in response to Niles Ridgeman)Thanks Niles.
I looked for memtest and unless I am wrong, memtest will not test 10.6.2 it only goes up to Leopard. Plus to be honest I was a wee bit jittery about typing in stuff when I know so little about how the darn machine works in the first place.
However, In trying to upgrade my Spyder color calibration programme earlier, Spyder insisted I upgrade Snow leopard even though I was convinced I had the lates version. However, I did up grade S Leopard again, and for the moment, at least the machine appears to be performing quite well. I am yet to use to photoshop so that will nbe the next test.
Thanks once again for all your input
Regards
Mark
