SOLVED
String Concatenation
Avatar
Level 2
I have five text fields with name like Name_1, Name_2, Name_3, Name_4 and Name_5.
Each of these will contain just one character like A B C D  and E.
I want a 6 th text field (hidden) to have the full value as ABCDE after the user exits the text field Name_5.
form1.Fragment1.Name_5::mouseExit - (JavaScript, client)
var string1=form1.Fragment1.Name_1.rawValue;
var string2=form1.Fragment1.Name_2.rawValue;
var string3=form1.Fragment1.Name_3.rawValue;
var string4=form1.Fragment1.Name_4.rawValue;
var string5=form1.Fragment1.Name_5.rawValue;
var string6=form1.Fragment1.Name_6.rawValue; // This is blank presently.
form1.Fragment1.Name_6.rawValue = string6.concat(string1, string2, string3, string4, string5);
Please help me how would this work.
Thanks and Regards,
Sonika
1 Accepted Solution
Avatar
Correct answer by
Level 3
Here the update for the example.
Make sure the language is set to FormCalc. You were Mixing the language.
The last digit of the policy I placed an EXIT event to pass the value to Myfield in your form.
Avatar
Level 2
Thanks a lot! This was a very helpful.
Please help me by telling me what setting have you done.
On the last text field I did make it a calculated field and checked radio button as Calculated script but
looks like there is more because after updating PDF send by you the fragment I made works perfect but
if I start afresh it does not work.
Please guide.
Thanks and Regards,
Sonika
Avatar
Level 3
Can You Attach Your File So I Can See The Problem?
Avatar
Level 2
The textfield is not getting the value concatenated whereas the field copied from your form does. Am i missing some setting?
Please see attached.
Avatar
Level 10
The code must be of FormCalc (not Javascript)
See the modified PDF attached.
Also look at the new feature of Designer 8.x which make your life simple.
Nith
Avatar
Level 2
HI,
I know about the new feature but my requirement is what is done earlier.
Also, Please give me the equivalent javascript code, I cannot use Form Calc.
Sonika
Avatar
Correct answer by
Level 3
