Hello,
I am experiencing an issue with audio in AE CS4 where I keep getting a small "pop" at the end of the audio track. I have a .wav file in a composition with a couple of key frames so the audio fades out. The audio fades to -48db so it should go completely silent. When playing back there is a small "pop" at the end of the composition. I have tried multiple audio files in AE with the same result.
When I bring the same file into PPro CS4 or SB CS4 and throw a "constant power" transition or fade it out, it is fades out beautifully, so I'm convinced it's AE.
I am importing a Adobe Dynamic Link (LOVE ADL) of the composition into a PPRO sequence. I have tried rendering the file straight out of AE and then importing the actual rendered file into PPro but the same "pop" result. So I'm pretty sure it's not the Dynamic Link either.
Any thoughts would be appreciated.
Thank you in advance and for taking the time.
Shane
Vista Home (Clean Install)
CS4 Master
Cute FTP, FireFox and Safari are the onyl additional installs.
Try sticking a -192dB key frame after your -48dB keyframe.
You say the audio fades to -48dB . . . how long is the fade ?
