Hello,
I'm currently moving from ES to ES2 and want to better understand the data model capability in Workbench ES2.
I think the problem I have is the way in which I am approaching it.
I have created a form, in Designer, and have an XML Schema that I am using for a data connection.
In ES I could simply create a Form Guide based on that form, however in ES2 I need to have a Data Model.
I understand the principles of the Data Model however I can't see how to use my XML Schema as the basis of one - or am I approaching this the wrong way?
Any guidance is appreciated.
Tim
Total Likes
Right, helps if you do a bit of reading and searching.
I have found out that xdp support in FormGuides will be released in Service Pack 1 of ES2.
So I guess my question is now two-fold:
1. When is Service Pack 1 of ES2 to be released?
2. How do you generated/create a PDF from a FormGuide (especially if you want to include a PDF view as part of the Guide)?
Tim
Total Likes
here is the help topic about including the PDF view of the data -- I've never done this before so I can't help much more that this:
http://help.adobe.com/en_US/livecycle/9.0/workbenchHelp/003614.html
scott
Total Likes
