I have thousands and thousands of rtf documents that need to be converted to pdf. Anybody like to tell me how to do this in ColdFusion 8?
A conversion like the one you describe is probably best handled by batch conversion software that can make the RTF to PDF conversion. ColdFusion probably won't be the best choice for you here - Although you can read in the contents of the RTF file using <cffile>, coldfusion won't know how to translate the RTF format into HTML formatting needed to generate a PDF via <cfdocument>. If you absolutely had to use coldfusion to complete the project, you could look into using Java packages (maybe iText?) to perform the task, but I'm not sure if libraries exist out there that do what you are asking. However, since there are specific software applications written specifically for this sort of thing, you can probably find inexpensive software that has the functionality that you want.
<!--- source:http://livedocs.adobe.com/coldfusion/7/htmldocs/wwhelp/wwhimpl/common/html/wwhelp.htm?context=ColdFusion_Documentation&file=00001585.htm --->
<cflock scope="Application" type="exclusive" timeout="120">
<cfif not StructKeyExists(application, "MyWordObj")>
<!--- First try to connect to an existing Word object --->
<cftry>
<cfobject type="com"
action="connect"
class="Word.application"
name="Application.MyWordobj"
context="local">
<cfcatch>
<!--- There is no existing object, create one --->
action="Create"
context="local">
</cfcatch>
</cftry>
<cfset Application.mywordobj.visible = False>
</cfif>
</cflock>
<!--- Convert a Word document in temp.doc to an HTML file in temp.htm. --->
<!--- Because this example uses a fixed filename, multiple pages might try
to use the file simultaneously. The lock ensures that all actions from
reading the input file through closing the output file are a single "atomic"
operation, and the next page cannot access the file until the current page
completes all processing.
Use a named lock instead of the Application scope lock to reduce lock contention. --->
<cflock
name="WordObjLock" type="exclusive" timeout="120">
<cfset docs = application.mywordobj.documents()>
<cfset docs.open("c:\ColdFusion8\wwwroot\RTFtoPDF\temp.rtf")>
<cfset converteddoc = application.mywordobj.activedocument>
<!--- Val(8) works with Word 2000. Use Val(10) for Word 97 --->
<cfset converteddoc.saveas("c:\ColdFusion8\wwwroot\RTFtoPDF\temp.htm",val(8))>
<cfset converteddoc.close()>
</cflock>
<!--- Read the HTML file --->
<cffile
action="read" file="#expandPath('temp.htm')#" variable="fileToConvert">
<!--- Convert from HTML to PDF--->
<cfdocument
overwrite="yes" filename="#expandPath('temp.pdf')#" format="PDF"><cfoutput>#fileToConvert#</cfoutput></cfdocument>
<p>Conversion from temp.rtf to temp.pdf complete</p>
Thank you. My problem is that there is no Word on the server itself.
Guess I will have to see what I can do about that.
I don't think you require Word on the server. Just run the code and see.
this works great!! thank you BKBK !
OK, Suaveodean
Kept meaning to get back to this one. You must have Word installed to use the Word object. The problem I'm having still is that Office has so many security issues that the security people won't install it on the new server so I have to stay with the old server. Maybe I will use this code tho to just convert it on the old server and move it to the new server.
I got redirected to a different problem and am just now getting back to this one.
But by now the answer is very different: install OpenOffice on a server with ColdFusion 9 and use the conversion capabilities of the new cfdocument tag.
Yeh, that's the ticket. They just upgraded to 8 about a year ago and just getting everything running in 8 and now I'll walk in and say "Gotta go to 9. Please fork over a bunch of money for that" And then there is the time to have it approved by the security gestapo and so on and so on.
At this point that is not an option.
the iText project is improvng this as we speak, cfsearching's got a good blog post on it: http://cfsearching.blogspot.com/2009/04/itext-preview-of-things-to-come-someday.html
