My company houses its product knowledgebase on a hosted Confluence site, and I want to be able to search the KB from within our WebHelp system created in RoboHelp 7. Ideally, I'd be able to integrate the canned search functionality in WebHelp with the search API for Confluence, but I would definitely settle for a search box embedded in a WebHelp page that searches the KB. Any tips or advice would be greatly appreciated.
- Steve
See ZoomSearch on my site. Would that work for you?
It looks like it might, Peter. This statement in particular looks promising: "Ability to include a search on an intranet or other information sources outside the project".
Now I just need to figure out the other end -- searching a Confluence site using this tool. I have a feeling it might not be all that straightforward. Hopefully either the ZoomSearch documentation or the Confluence documentation will help.
Looks like I got the answer to my question on the ZoomHelp user forum, Peter. Probably won't work without "a fair amount of custom development." Oh, well.
In Ray's response he says "One which happens to be hosted locally on the hard disk, and another which is served over the web". The webhelp is not being hosted locally so it might be worth pointing that out. If both information sources will be on the same server you should state that too.
Another option is to have a ZoomSearch setup as in the demos on my site where the user can choose which search to use. One button would bring up a ZoomSearch search of the help and another button the search of Confluence.
Ray's assessment is accurate ... my WebHelp system actually does install on the user's hard drive, and the Confluence site is on the Web.
Your other suggestion could work, but I think for the time being I'll just go with my current solution, which is to include a link to the online knowledgebase both in the TOC and the welcome page. I'll take another look at your samples, though. Thanks!
