1. Re: Fresh CS4 Encore - won't start
John T Smith Jan 23, 2010 10:24 AM (in response to CJGerow)How did you install, and how are you running?
Encore and Premiere Pro MUST be installed and run from the Administrator account
2. Re: Fresh CS4 Encore - won't start
CJGerow Jan 23, 2010 12:17 PM (in response to John T Smith)John,
I don't know how I installed Master Collection, but I do have Premiere Pro running (as Administrator) and I did the same for Encore - I found that one here on the forums. Can I assume that it is installed correctly?
Chris
3. Re: Fresh CS4 Encore - won't start
Bill Hunt Jan 23, 2010 8:51 PM (in response to CJGerow)OK, when a program crashes, or fails to launch, there is often a breadcrumb trail. This ARTICLE will give you tips on finding clues amongst the breadcrumbs in Event Viewer.
Good luck,
Hunt
4. Re: Fresh CS4 Encore - won't start
CJGerow Jan 25, 2010 8:13 AM (in response to Bill Hunt)Bill,
That Article you referenced - I've looked in the event viewer and found nothing. It also had a video of Mark Rissinovich. What and amazing character. I've gone through part of his 1:15 minute video, and download his sysinternals.zip file and in the process of looking for what is preventing Encore from completing startup. Unfortunately it is a very long process - 400,000's entries and that's with a filter.....
I'll let you know what I found.
Chris
5. Re: Fresh CS4 Encore - won't start
CJGerow Feb 15, 2010 1:16 PM (in response to CJGerow)Well - I've finally got it to work. I really don't know why but here is what I did. I bought a new system and installed Windws 7 (64). I then applied all the maintenance to win7. Before, I installed MC and then the Win7 maintenance. Then I installed Master Collection, and brought up Encore - Voila - It works. Then I applied all the maintenance to Master Collection and I'm up and running.
I knew this was a wierd one - and it must have been something I did.
ChrisG
6. Re: Fresh CS4 Encore - won't start
Bill Hunt Feb 15, 2010 2:21 PM (in response to CJGerow)Chris,
I'm up and running.
That is great news!
Thanks for reporting your success. Sorry that it took a new box, but that does point to something in the System/OS as being the culprit.
Good luck,
Hunt
7. Re: Fresh CS4 Encore - won't start
Glenn Davidson Feb 17, 2010 2:15 PM (in response to CJGerow)Sorry no solution, I've got the same problem, new copy of CS4 on windows XP all products work except Encore. I don't get a intro screen just mouse changes to loading then stop and nothing happens? After trawling many forums it seems it has to do with the amtlib.dll if you rename this it then at least has an error message pop-up saying it can't load Encore because it can't find this file. Unfortunately most of the sites that say they can fix the problem are torrent sites and require you to overwrite this file with theirs? I can't find anything on the Adobe site.
8. Re: Fresh CS4 Encore - won't start
Bill Hunt Feb 17, 2010 4:22 PM (in response to Glenn Davidson)Interesting. I had not read of that file causing an issue. Now, there is a Roxio element (I know, but it's part of Encore, at least CS4), that has given people fits. Name escapes me, but there is an update on the Roxio site (IIRC). Do not recall the behavior that this element was causing, but you might want to Search this forum for "Roxio." There will be several threads on their packet-writing modules, and just ignore those. As I recall, Jeff Bellune was part of one of those threads, so I'd filter on People - Jeff Bellune.
Good luck, and I'll see if I can find one of those threads,
Hunt
PS - I am also not a fan of anything from a torrent site. Maybe I am cruel, but I feel that many get what they deserve with neat little key-loggers, Trojans and WORMS.
9. Re: Fresh CS4 Encore - won't start
Glenn Davidson Feb 17, 2010 4:36 PM (in response to Bill Hunt)Hi thanks Bill, Yeah I shouldn't have mentioned that but those sites were all that was coming up with any info? Good news is my 3rd install has worked! I've just burnt my first encore project. thanks again Glenn
10. Re: Fresh CS4 Encore - won't start
Bill Hunt Feb 17, 2010 5:04 PM (in response to Glenn Davidson)Glenn,
You are doing better than I am. My Searches are not showing up what I want. Maybe I am only remembering part of the story, and have the software developer confused. Jeff Bellune is a MOD here, so maybe he'll stop by and give me some help, plus point everyone to the proper discussion.
As for the torrent sites - we all know that they exist. When I do a Google Search, I normally will put "torrent" into the "Do Not Show These Words... "
On a recent Search for the MS C++ Runtime .dll deliverable for another thread, the first 100 hits were torrent sites. Wow, they sure do know how to "play" Google.
Sorry that either my memory, or my boolean is so very bad.
Still, you got it going, and that is great news!
Hunt
11. Re: Fresh CS4 Encore - won't start
CJGerow Feb 18, 2010 6:54 AM (in response to Glenn Davidson)Glenn,
I think there is a conflict with Windows 7. I did things in different order and Encore came up. On the first try, I installed Wondows 7, then Premiere only which brought in Encore. This worked, so I installed the maintenance for Windows 7, then the reset of Master Collection, and the maintenance for MC. This is when I ran into the problem that Encore wouldn't start.
On the second try, I Installed a fresh copy of Windows 7, then all the mainenance. Next I installed all of MC, and then all the mainenance. Everything works now.
This is why I'm looking at Windows 7 as the culprit.
ChrisG
12. Re: Fresh CS4 Encore - won't start
Bill Hunt Feb 18, 2010 7:54 AM (in response to CJGerow)Everything works now.
That is music to our ears!
Thanks for listing the steps that you took to get it all up and running.
I'm contemplating Win7 and a new workstation, but am holding off until SP-1, especially as XP-Pro is running so well still, and I am not yet doing HD/BD work.
Good luck,
Hunt
13. Re: Fresh CS4 Encore - won't start
CJGerow Feb 18, 2010 8:22 AM (in response to Bill Hunt)Bill,
I can add - my nephew works for Blackboard and he has 1,000's of systems in their own network. He has made the commitment 2 months ago to move them all to Windows 7. That was my cue. I've been running Windows 7 for 2 months - and I can say much to my surprise - it's stable as a rock. My boot time is measured in seconds. Things are in different places but it's all there.
I ran it on a 5 year old system first. I found answers to all the problems I had on the internet - they were because my components are so old. When I installed it on new hardware - not a single hangup. And they already have drivers for my video card (NVIDID GeForce 285).
Thanks for all your help,You guys are great....
ChrisG
14. Re: Fresh CS4 Encore - won't start
Bill Hunt Feb 19, 2010 9:23 AM (in response to CJGerow)Chris,
So far, the only negative that I have heard on Win7 is with the dearth of drivers for the 64-bit versions. Speculation is that by SP-1, most of those driver issues will be cleared up. Now, my reports come from the Adobe fora, so outside of PS, PrPro/En, InDesign, AI and similar, there could be issues, unknown to me. I don't hang out in hardware, or OS fora, so do miss a lot. Most, however, report that Win7 is everything that Vista was touted as, plus more. Put aside those 64-bit drivers, and everyone loves Win7. Though I love XP-Pro, it is getting time to move on, and I'm just glad that I missed Vista-anything.
Good luck, and thanks for the report,
Hunt
15. Re: Fresh CS4 Encore - won't start
Ratherfly Feb 20, 2010 8:16 AM (in response to CJGerow)Everyone is saying there is an issue with Win7, and I have the exact
same problem on two machines, one running XP/32 and the other running Win7/64. In both cases Encore CS4 freezes. Everything else works fine except Encore. Whether I start from shortcut or thru dynamic link I get the same freeze.
Any input would be great
Bill
16. Re: Fresh CS4 Encore - won't start
Ratherfly Feb 20, 2010 8:32 AM (in response to Ratherfly)Sorry, I found info using Roxio update to correct problem, just dont know why it has happened on two machines.
Info found in post for "Bluray: Encore crashes in loading timeline" - Thanks Ann
17. Re: Fresh CS4 Encore - won't start
John T Smith Feb 20, 2010 10:30 AM (in response to Ratherfly)>dont know why it has happened on two machines
Roxio module is part of Encore... so every Encore must be updated with the Roxio fix
18. Re: Fresh CS4 Encore - won't start
Bill Hunt Feb 20, 2010 11:24 AM (in response to John T Smith)John,
I went looking for the Roxio update fix, but could not find it. Guess my boolean let me down. I searched for you, Ann Bens and Jeff Bellune in People, but could not locate the main thread on this. Do you happen to recall the thread's title, or have a link? I thought I'd bookmarked it, but did not.
Hunt
19. Re: Fresh CS4 Encore - won't start
Stan Jones Feb 20, 2010 2:23 PM (in response to Bill Hunt)Is this the thread?
http://forums.adobe.com/message/2544986#2544986
This is the Adobe kb fix which I think points to the roxio site:
http://kb2.adobe.com/cps/516/cpsid_51665.html
This is the roxio link:
http://kb.roxio.com/search.aspx?URL=/content/kb/General%20Information/000070GN&PARAMS
I don't know that the issue is a "Roxio" module. Encore has always (?) been a Sonic base, and it is not clear to me how this error operates. All the information we have does not make sense of this fixing a problem with anything other than Windows 7, but who knows.
