I'm using RH8 under WinXP. I use variables for our product names (=single software modules). This makes it easier to change the name, if a product name has changed. For each of these products there is a single RH-project. Now I want to import a set of variables, that I've created in one of those projects, to another project. Up to now, I haven't found an export/import option in RH for these set of variables. Is there a possibility to import/export these variables?
Kind regards
Stefan
Set up a test project close it, copy the rhvariable.apj file from a project with the variables into it. Reopen the test project.
thx for your answer. This recommendation did work.
Greetings
Stefan
