1. Re: Add effects to clip in timeline - CS4
shooternz Feb 18, 2010 1:32 PM (in response to rico1931)PPRO is "non destructive" and anything you do in the timeline does not affect the source footage (source file).
[Unless you export it as the same filename and type to the same location as the source file}
2. Re: Add effects to clip in timeline - CS4
rico1931 Feb 18, 2010 1:48 PM (in response to shooternz)Yes you are right..
Well I just found a work around.. I just made a sub clip of the clip in my time line and just used that over my orig clip and blurred out what I wanted.. took me a whole hr to figure out tho.. but i guess that's why they call it learning right?!?!?!
3. Re: Add effects to clip in timeline - CS4
rico1931 Feb 18, 2010 1:49 PM (in response to rico1931)Can you give points to yourself?
4. Re: Add effects to clip in timeline - CS4
shooternz Feb 18, 2010 1:53 PM (in response to rico1931)Why did you need the sub clip?.
You could have used the original twice.
5. Re: Add effects to clip in timeline - CS4
the_wine_snob Feb 18, 2010 5:11 PM (in response to shooternz)Craig,
I'm with you. One can have a virtually infinite number of "instances" of a Clip on the Timeline, and each can have totally different In & Out Points, if necessary. Each can have myriad Effects, unique to each instance.
I would have just done it that way, but then I like to keep things simple (except when Colin tries to take my Track Matte Keying away from me).
Hunt
6. Re: Add effects to clip in timeline - CS4
rico1931 Feb 22, 2010 6:00 AM (in response to the_wine_snob)Yup you guys are right.. I just made a copy and it worked fine.. just had to position the blur in the right spot ... thanks!
