I purchased CS4 Web premium which comes with Soundbooth. I later purchased Premiere Pro CS4. When I try to use File>Adobe dynamic link>Import Premiere Pro Sequence, "Import Premiere Pro Sequence" is greyed out. Also, if I go to import - it looks as if Premiere Pro files are not supported?
Any Suggestions?
Randy
You need to create a multi-track file. File>New>Multitrack File (Ctrl+Shift+N). At this point, you will be able to import using dynamic link from either PPro or AE. If I may ask, why are you importing from PPro? You're better off dynamic linking from PPro to Soundbooth, that way you'll receive immediate changes applied to PPro when you change something in Soundbooth.
