In my Webhelp output, i have added the Hide Navigation icon.
My development team has a requirement that the Hide Navigation icon should :
on click , Hide TOC
on Click, Unhide TOC.
Currently, it can only Hide..and one has to click the Contents(TOC) icon to unhide ..They are not very comfortable with this.
Can anyone please help me modify the code to add the Unhide feature too?
Nanditha
That's the way it works in all WebHelp, other tools as well I believe, and everyone else is comfortable with it.
I guess you might be able to get someone to write a script for a button to replace the Contents button that does what you want. However, you would have to turn off the RH Contents button and then the help would open to either the Index or the Search. On balance, unless anyone else has a suggestion, I think you will have to accept the way it is. It is standard.
Ok..I have a slight problem in knowing how and where to edit the code..
If i try and add some code in the skins editor, then it might cause an impact while compilation and resulting in an error.
I want to know if someone has tried on some code for this function.
-Nanditha
What I was suggesting is that one of your developers would have to write a script for that button. If they can make a button work the way you want, I still don't think you will like the result. Compile some help with the Contents button deselected to see what I mean.
If your attempts do fail, it will not wreck anything as you would simply remove the button you create. In any case, with things like this it is always a good idea to create a copy of your project and test on that.
I have not seen anyone post that they have written such a piece of code and I am not sure it is possible. Rick Stone will be online when America wakes up, maybe he has seen someone with this requirement before.
You could visit Rick's site at http://www.robowizard.com and download his Skinny on Skins and Tips and Tricks. Just possible something is covered there.
Hi all
I believe what is being sought is actually the behaivor for non-skinned WebHelp. The topic has a link to collapse the navigation if the navigation is shown. Otherwise, the topic has a link to show the navigation if it's been hidden. The link may be text or an image and is configured via the WebHelp properties dialogs.
When I read this thread I wonder if the answer is to possibly just forego using a skin and instead opt for the "Traditional - No Skin" type of WebHelp. After all, they seem to be avoiding use of the skin.
If by some odd chance the skin is actually DESIRED, I suppose one could accomplish this with relative ease by taking the following actions.
Generate WebHelp twice. Once with a Skin to location A and once with the Traditional Style non-skinned WebHelp to location B. Then copy the topic files from Location B and overlay the files in location A.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
I am currently using the Default skin for generating the Webhelp output.
What i basically want to do is, add to the functionality of the Hide Navigation icon, some code, so that when its clicked again, it should function like the contents icon. To display back the TOC contents panel.
I dont know where i could add the code, which one of the Java scripts am i supposed to search?
I want to check the code for the Contents icon , so that i could manage to add the same code for the Hide Navigation icon code.
Hi again
I've outlined the simplest possible approach for you. If you don't like that approach and still insist on doing this the JavaScript way, you will need to produce the output using the traditional style, then pick apart the code behind the links that collapse and expand the TOC in order to apply it to a skinned version.
Cheers... Rick
Hi Rick,
I was looking for the latest version of your Skinny on Skins chm file. Kindly point me to the latest version.. The one i have was last updated in 2004 i guess..
Nanditha
Hi Nanditha
I guess you are the same Nanditha that asked the same question over in the TWI forums.
Sorry, but the Skinny file is up to date. It's not been updated in a very long time.
Cheers... Rick
