When I open an existing process, Workbench is being shutdown with attached message.
Exit code -1073740940
Client env is - Vista 32bit // Java 1.6.0_18 // 4GB RAM
What's wrong?
Total Likes
Was this map created in an earlier version of the product and imported?
Can new applications be created/saved/opened?
Was it working before and then stopped working? If so what changes have been applied?
Is it just one user having the problem or anyone that attempts to open this process?
Is Office 2010 with infopath or groove installed"
Is Flexbuilder also installed on this machine?
Total Likes
The map I tried to open is imported sample by LC installer.
This is not an earlier version of it.
This JVM termination issue happens when i tried to create a new map too.
This issue happens everytime after I install Workbench.
No office 2010, infopath, groove, FlexBuilder.
Any additional info?
Total Likes
I am also facing the same exact issue.
My clicnt env- Windows 7 (32 bit os) 3 GB ram
Using Turnkey Jboss installation , ms sql server 2005 sp3
I have answered your questions here
Should i make some change for java heap space arguments -xmx -xms if so where should i change?
If Flex Build is installed what is the problem?
Some more info may be helpful.
-> When i start the workbench a javaw.exe runs in my task manager -. process , i right click on javaw.exe -> Open filelocation
-> When i check of java -version in that location through cmd its jdk 1.6 build 07 is that ok?
Please clarify
Total Likes
