When I try to open RoboHelp, I get a dialog box that reads "DAO is not installed. This application cannot run without DAO, so please install DAO then try running the application again." What is DAO? Has anyone else ever had this?
DAO stands for Microsoft's Data Access Objects. It is installed in C:\Program Files\Common Files\Microsoft Shared\DAO. It is required for working with databases. If it is not installed on your machine, you can get it from MSDN.
K
Further to Kutra's suggestion:
This thread has some useful info on DAO
http://forums.adobe.com/thread/249697
John Daigle
Adobe Certified RoboHelp and Captivate Instructor
Evergreen, Colorado
www.showmethedemo.com
Should I do the Start and Run process described in this thread?
Thank you for the help. Had to reinstall Jet35sp3 in order to get RH to work. I am up and running.
Thanks again!
