Revision: 14371
Revision: 14371
Author: klin@adobe.com
Date: 2010-02-23 14:37:38 -0800 (Tue, 23 Feb 2010)
Log Message:
Merge revision 14369 from 4.x to trunk
Fix for icons that shouldn't be mirroring. This fix is similar to the one found in UITextField Modified FlexBitmap to detect whether the closest parent is mirrored when added to the display list, and adjust the transform matrix accordingly. Also, I overrode the x, width, and height properties to again, adjust the transform matrix when necessary.
http://bugs.adobe.com/jira/browse/SDK-25417 - Button icons
http://bugs.adobe.com/jira/browse/SDK-25498 - Alert icons
http://bugs.adobe.com/jira/browse/SDK-25511 - Accordion icons
http://bugs.adobe.com/jira/browse/SDK-25512 - ComboBox icons
QE notes: None
Doc notes: None
Bugs: SDK-25417, SDK-25498, SDK-25511, SDK-25512
Reviewed By: Hans
Tests run: checkintests
Is noteworthy for integration: No
Ticket Links:
Modified Paths:
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/FlexBitmap.as
Property Changed:
flex/sdk/trunk/
