OS: Solaris
LiveCycle ES 8.2 Update 1 SP2
Anyone has encounter the following issue with form rendering, where RenderFormException message:Cache may be in inconsistent state is thrown?
Appreciate if anyone can provide some pointers or directions on resolving this issue, Thanks.
<Feb 9, 2010 4:41:31 PM SGT> <Error> <com.adobe.livecycle.formsservice.exception.FormServerException> <BEA-000000> <ALC-FRM-001-061: Cache may be in inconsistent state. Unable to read file: .cciob/appsvr/bea/weblogic/config/ADOBE/adobe/ADOBEManagedServer1/FormServer/Cache/1254114961771/Rendered_Cache/repository%3A%2F%2F./PDFForm/PDFForm/ClientRendered/1.65RE_00000000000Cache_-556714353//fm_mng_services/projecta/forms/form1/fm_type_a_en.xdp.cci>
<Feb 9, 2010 4:41:32 PM SGT> <Error> <com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker> <BEA-000000> <An exception was thrown with name com.adobe.livecycle.formsservice.exception.RenderFormException message:Cache may be in inconsistent state. Unable to read file: .cciob/appsvr/bea/weblogic/config/ADOBE/adobe/ADOBEManagedServer1/FormServer/Cache/1254114961771/Rendered_Cache/repository%3A%2F%2F./PDFForm/PDFForm/ClientRendered/1.65RE_00000000000Cache_-556714353//fm_mng_services/projecta/forms/form1/fm_type_a_en.xdp.cci while invoking service FormsService and operation renderPDFForm and no fault routes were found to be configured.>
Was not able to find the error code <ALC-FRM-001-061> in the error code reference http://help.adobe.com/en_US/livecycle/8.2/errorCodeReference.pdf
Total Likes
Anyone? encounter this issue before?
The renderPDFForm service component is executed in a short-lived process and 'Cache Form on Server' option set to empty.
Anyway to debug the cache related issue?
Thanks in advance.
Total Likes
Just out of curiosity, when you say that the cache is set to empty, do you mean that its set to False? Have you tried setting it to false?
Total Likes
Nope, 'Cache Form On Server' is left unselected as per the option when then 'renderPDFForm' component is drag out from the service view.
I didn't tried selecting it to 'False' as it is mentioned that the default value is already 'False'.
Total Likes
