Hi, the problem is inspite of trying all the listed 4 option
we are unable open the help with synchronised TOC in the
application. (For example, when we press F1 on a screen in the
application, the context senstive help opens without auto
synchronising the TOC. We have check all the option in Properties
tab also)
We are not facing the problem when we are checking the same
in output folder. The problem arises only after integrating with
the application.
While finding solution, this link :
http://www.grainge.org/pages/authoring/merging_webhelp/merging_method.htm#step_8"
provided us an information that we need to modify the whthost.js
file in the output folder each time when we generate.
We need your help in deciding whether this is only the option
to call third level book in application using 7.0 or we have any
one time solution.
