I have a text input field on the timeline that I want the user to enter specific information in. When that information is correctly entered, I need the timeline to progress.
I successfully used the following AS2, but I cant find corresponding code for AS3
on (keyPress "x") {
gotoAndPlay("s05");
Any help on converting this function to AS3 is greatly appreciated.
I'm a little surprised you don't get any error message, but I guess your incomplete conditional doesn't break any laws as written (ended prematurely with a semicolon...
if(pane.text == "x");
gotoAndPlay("s04");
should be...
if(pane.text == "x") gotoAndPlay("s04");
You can use an Event.CHANGE listener for the textfield and then test its value in the event handler function to see if it agrees with the required string...
inputtField.addEventListener(Event.CHANGE, testEntry);
function testEntry(evt:Event):void {
if(inputField.text == "whatever"){
// do stuff
Thanks, I modified the code to match the text input file name, and added a line for the action I want:
pane.addEventListener(Event.CHANGE, addEntry);
function addEntry(evt:Event):void {
gotoAndPlay("s04");
I do not get anny errors, but nothing happens.
gotoAndPlay("s04");
should be...
Thanks, works perfect!
You're welcome
