1 2 Previous Next 62 Replies Latest reply on Aug 18, 2011 3:56 PM by Chris Cox Go to original post
      • 40. Re: Strange system log error from Photoshop CS4
        Dan_Perfect
        HI,
        Did anyone actually come to a conclusion about what this error is? I've been driving myself nuts with trying to troubleshoot this, and not figured it out..
        I'm getting the same error as the OP,
        25/02/2010 09:48:03 Adobe Photoshop CS4[255] Adobe Photoshop CS4(255,0xa0012500) malloc: *** mmap(size=17002496) failed (error code=12)
        *** error: can't allocate region
        *** set a breakpoint in malloc_error_break to debug
        Goes on endlessly, and eventually CS4 hangs, often during a save or open operation.
        I have tried lots of re-installs, isolating memory etc. 10.6.2, 12GB RAM, 2 x 2.26GHz Quad Core.
        I don't have any 3rd party plugins, and it happens for me whichever clean installed HD I boot off.
        Im working with reasonably large files, up to a gig, but I keep an eye on the memory allocation, and I always have plenty of headroom..
        Some help on this would be appreciated!
        Dan
        • 41. Re: Strange system log error from Photoshop CS4
          MuggeGHQ
          Hi Dan_Perfect
          I still have the problem
          And also 12GB of Ram. I never tried change the amount of ram back to something else.
          Before i installed the extra memory. There was no problems ???
          Strange really.
          • 42. Re: Strange system log error from Photoshop CS4
            Wade_Zimmerman Level 6
            It was suggested it might be hardware related have you investigated did you remove the RAM you installed?
            It could be poorly installed not properly seated or it can be bad RAM. Why not find out?
            • 43. Re: Strange system log error from Photoshop CS4
              Level 7
              At this point, I'm reasonably sure that the messages are an OS thing.
              And I'm pretty sure you can just ignore them.  They are status information, not actual errors.  (someone was just overzealous about reporting allocation failures)
              • 44. Re: Strange system log error from Photoshop CS4
                MuggeGHQ Level 1
                Hi both, and thx for all your help and suggestions
                Yea. i think your right about you can ignore the error.
                The only thing that bothers me are after you have spend a lot of time on a picture and you want to safe it.
                Then this happen. But i get around this by just saving the picture to the desktop and then move it to the
                right folder after. Then restart Photoshop. Photoshop needs to restart everytime you get this error because
                the error message dosent go away before photoshop is restarted.
                I learned to live with it for now and i think it is a memory question.
                It only happen when i have 12GB or 16GB installed. Not 10GB or 8, 4 or something. 12GB and 16GB ???
                And it wasn't there when i had 10.5.4 or 5 installed, it came after i updated my system to 10.5.8. Weird.
                I did tried to swop the ram blocks around and also ran some test on them. All are good.
                It is a combination of exactly the amount of memory installed funny enough. Thats what i think anyway.
                But i'm not a technition, so what do i know  its just a feeling.
                Again. Thx for all the replays here and i will follow the tread and see if something comes op one day.
                Photographer
                Erik DK
                • 45. Re: Strange system log error from Photoshop CS4
                  Level 7
                  Except that it isn't an error, and the message has no effect on Photoshop's operation....
                  What happens is that the OS says "there is 4 meg available to allocate", and Photoshop thinks it can safely allocate 2 Meg.  But that allocation fails because the address space is fragmented.  Then Photoshop backs off the allocation to 1 Meg and tries again.  But when the 2 Meg allocation failed, the OS printed a message to the console (probably debugging code mistakenly left in the OS).  Photoshop keeps working, the OS keeps working - nothing should fail.  It's just a warning message from the OS code that really doesn't mean anything.
                  • 46. Re: Strange system log error from Photoshop CS4
                    MuggeGHQ Level 1
                    yes, it is just a message but not quite.
                    Everytime i get the error i have to restart photoshop before it works normal again.
                    If the error message comes ones. It dosent go away before a restart and i cant save
                    any pictures to my main picture drives before i restart PS.
                    So its not just a error message and nothing else. That would have been alright.
                    But woulden it be possible to make a PS update that fix this error message ?
                    • 47. Re: Strange system log error from Photoshop CS4
                      Level 7
                      Again, it is not an error message - that message is normal, and just the OS reporting more stuff than it should to the console.  Other users have that message come up in the console all the time - with no ill effects.   If Photoshop fails to allocate memory, it just frees up some memory and tries again until it succeeds.  Again, this happens all the time.
                      Something else is doing on that prevents you from saving, something that might be related to the allocation errors, but probably not.  If a third party plugin or driver is leaking memory, or messing up the OS memory system -- that could cause problems down the road and might cause allocation error messages.
                      But while you are seeing problems saving files, other users are not.
                      Adobe hasn't seen such a problem.
                      And we can't fix what we've never seen (and have no idea what might be causing it).
                      So, calm down and let's see if we can figure out what is happening to your system, and why it only happens to you.
                      Do you use any third party plugins?  (try disabling them)
                      Have you used a scanner driver inside Photoshop? (try removing the TWAIN plugin, scanner drivers are notorious for causing problems)
                      Have you printed anything before this problem occurs? (printer drivers can also cause some problems)
                      • 48. Re: Strange system log error from Photoshop CS4
                        Dan_Perfect Level 1
                        Hi again
                        Well its not just the OP that this happens to..
                        Although I dont seem to have his problem of the save location being important to success of the operation..
                        I have tried various combinations of RAM, tested it exhaustively, and it makes no difference to the proliferation of the memory error reports, and eventually to the crashing of CS4, most often in a save operation. I have reinstalled the system, run diskwarrior, disk utility etc etc, and removed all 3rd party plugins. Changed the memory settings in CS4, and changed scratch disk allocations. Don't know what else to do..
                        All I can do at the moment is save at 10min intervals & hope each time that I get lucky.
                        • 49. Re: Strange system log error from Photoshop CS4
                          Level 7
                          Dan - what OS version are you using?  Part of what you describe sounds like MacOS 10.6 bugs (mostly fixed in 10.6.2).
                          • 50. Re: Strange system log error from Photoshop CS4
                            davidsanger Level 1
                            I also just had the same problem as the OP, repeated malloc errors during a save. The console logs also said
                            Mar 26 22:08:41 MacPro Adobe Photoshop CS4[20718]: *** process 20718 exceeded 500 log message per second limit  -  remaining messages this second discarded ***
                            Running Activity Monitor and inspecting the Photoshop process, the first frame referred to the save dialog routine and a semaphore wait.
                            Could the OS call be hanging and unable to complete the calls necessary to start saving the file?
                            There is no disk activity and file was never written at all.
                            MacPro OS10.6.2 10GB memory
                            • 51. Re: Strange system log error from Photoshop CS4
                              Level 7
                              Well, that message just says that the log got a lot of messages - it doesn't say anything about what the error was.
                              semaphore_wait usually means that the app is waiting for the OS to complete something.
                              • 52. Re: Strange system log error from Photoshop CS4
                                MuggeGHQ Level 1
                                Hi.
                                Now i have another strange log error.
                                Photoshop CS4 Mac OS X 10.5.8
                                Beskrivelse: Logarkiv til systembegivenheder
                                  Størrelse: 180 KB
                                  Sidst ændret: 21/06/10 15.23
                                  Placering: /var/log/system.log
                                  Seneste indhold: ...
                                Jun 21 15:21:35 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:21:35 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextMoveToPoint: invalid context
                                Jun 21 15:21:35 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:21:35 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextAddLineToPoint: invalid context
                                Jun 21 15:21:35 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:21:35 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextDrawPath: invalid context
                                Jun 21 15:21:35 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:21:35 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextRestoreGState: invalid context
                                Jun 21 15:21:35 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:21:35 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSaveGState: invalid context
                                Jun 21 15:21:35 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:21:35 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineCap: invalid context
                                Jun 21 15:21:35 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:21:35 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineJoin: invalid context
                                Jun 21 15:21:35 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:21:35 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineWidth: invalid context
                                Jun 21 15:21:35 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:21:35 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextBeginPath: invalid context
                                Jun 21 15:21:35 mugge Adobe Photoshop CS4[24045]: CGContextSaveGState: invalid context
                                Jun 21 15:21:35 mugge Adobe Photoshop CS4[24045]: CGContextSetLineCap: invalid context
                                Jun 21 15:21:35 mugge Adobe Photoshop CS4[24045]: CGContextSetLineJoin: invalid context
                                Jun 21 15:21:35 mugge Adobe Photoshop CS4[24045]: CGContextSetLineWidth: invalid context
                                Jun 21 15:21:35 mugge Adobe Photoshop CS4[24045]: CGContextBeginPath: invalid context
                                Jun 21 15:21:35 mugge Adobe Photoshop CS4[24045]: CGContextMoveToPoint: invalid context
                                Jun 21 15:21:35 mugge Adobe Photoshop CS4[24045]: CGContextAddLineToPoint: invalid context
                                Jun 21 15:21:35 mugge Adobe Photoshop CS4[24045]: CGContextDrawPath: invalid context
                                Jun 21 15:21:35 mugge Adobe Photoshop CS4[24045]: CGContextRestoreGState: invalid context
                                Jun 21 15:21:36 mugge Adobe Photoshop CS4[24045]: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:21:36 mugge Adobe Photoshop CS4[24045]: CGContextSaveGState: invalid context
                                Jun 21 15:21:36 mugge Adobe Photoshop CS4[24045]: CGContextSetLineCap: invalid context
                                Jun 21 15:21:36 mugge Adobe Photoshop CS4[24045]: CGContextSetLineJoin: invalid context
                                Jun 21 15:21:36 mugge Adobe Photoshop CS4[24045]: CGContextSetLineWidth: invalid context
                                Jun 21 15:21:36 mugge Adobe Photoshop CS4[24045]: CGContextBeginPath: invalid context
                                Jun 21 15:21:36 mugge Adobe Photoshop CS4[24045]: CGContextMoveToPoint: invalid context
                                Jun 21 15:21:36 mugge Adobe Photoshop CS4[24045]: CGContextAddLineToPoint: invalid context
                                Jun 21 15:21:36 mugge Adobe Photoshop CS4[24045]: CGContextDrawPath: invalid context
                                Jun 21 15:21:36 mugge Adobe Photoshop CS4[24045]: CGContextRestoreGState: invalid context
                                Jun 21 15:21:36 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:21:36 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:21:36 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:21:36 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSaveGState: invalid context
                                Jun 21 15:21:36 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:21:36 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineCap: invalid context
                                Jun 21 15:21:36 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:21:36 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineJoin: invalid context
                                Jun 21 15:21:36 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:21:36 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineWidth: invalid context
                                Jun 21 15:21:36 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:21:36 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextBeginPath: invalid context
                                Jun 21 15:21:36 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:21:36 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextMoveToPoint: invalid context
                                Jun 21 15:21:36 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:21:36 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextAddLineToPoint: invalid context
                                Jun 21 15:21:36 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:21:36 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextDrawPath: invalid context
                                Jun 21 15:21:36 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:21:36 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextRestoreGState: invalid context
                                Jun 21 15:22:36 mugge Adobe Photoshop CS4[24045]: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:36 mugge Adobe Photoshop CS4[24045]: CGContextSaveGState: invalid context
                                Jun 21 15:22:36 mugge Adobe Photoshop CS4[24045]: CGContextSetLineCap: invalid context
                                Jun 21 15:22:36 mugge Adobe Photoshop CS4[24045]: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:36 mugge Adobe Photoshop CS4[24045]: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:36 mugge Adobe Photoshop CS4[24045]: CGContextBeginPath: invalid context
                                Jun 21 15:22:36 mugge Adobe Photoshop CS4[24045]: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:36 mugge Adobe Photoshop CS4[24045]: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:36 mugge Adobe Photoshop CS4[24045]: CGContextDrawPath: invalid context
                                Jun 21 15:22:36 mugge Adobe Photoshop CS4[24045]: CGContextRestoreGState: invalid context
                                Jun 21 15:22:36 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:36 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:36 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:36 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSaveGState: invalid context
                                Jun 21 15:22:36 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:36 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineCap: invalid context
                                Jun 21 15:22:36 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:36 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:36 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:36 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:36 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:36 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextBeginPath: invalid context
                                Jun 21 15:22:36 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:36 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:36 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:36 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:36 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:36 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextDrawPath: invalid context
                                Jun 21 15:22:36 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:36 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextRestoreGState: invalid context
                                Jun 21 15:22:41 mugge Adobe Photoshop CS4[24045]: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:41 mugge Adobe Photoshop CS4[24045]: CGContextSaveGState: invalid context
                                Jun 21 15:22:41 mugge Adobe Photoshop CS4[24045]: CGContextSetLineCap: invalid context
                                Jun 21 15:22:41 mugge Adobe Photoshop CS4[24045]: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:41 mugge Adobe Photoshop CS4[24045]: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:41 mugge Adobe Photoshop CS4[24045]: CGContextBeginPath: invalid context
                                Jun 21 15:22:41 mugge Adobe Photoshop CS4[24045]: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:41 mugge Adobe Photoshop CS4[24045]: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:41 mugge Adobe Photoshop CS4[24045]: CGContextDrawPath: invalid context
                                Jun 21 15:22:41 mugge Adobe Photoshop CS4[24045]: CGContextRestoreGState: invalid context
                                Jun 21 15:22:42 mugge Adobe Photoshop CS4[24045]: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:42 mugge Adobe Photoshop CS4[24045]: CGContextSaveGState: invalid context
                                Jun 21 15:22:42 mugge Adobe Photoshop CS4[24045]: CGContextSetLineCap: invalid context
                                Jun 21 15:22:42 mugge Adobe Photoshop CS4[24045]: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:42 mugge Adobe Photoshop CS4[24045]: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:42 mugge Adobe Photoshop CS4[24045]: CGContextBeginPath: invalid context
                                Jun 21 15:22:42 mugge Adobe Photoshop CS4[24045]: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:42 mugge Adobe Photoshop CS4[24045]: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:42 mugge Adobe Photoshop CS4[24045]: CGContextDrawPath: invalid context
                                Jun 21 15:22:42 mugge Adobe Photoshop CS4[24045]: CGContextRestoreGState: invalid context
                                Jun 21 15:22:43 mugge Adobe Photoshop CS4[24045]: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:43 mugge Adobe Photoshop CS4[24045]: CGContextSaveGState: invalid context
                                Jun 21 15:22:43 mugge Adobe Photoshop CS4[24045]: CGContextSetLineCap: invalid context
                                Jun 21 15:22:43 mugge Adobe Photoshop CS4[24045]: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:43 mugge Adobe Photoshop CS4[24045]: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:43 mugge Adobe Photoshop CS4[24045]: CGContextBeginPath: invalid context
                                Jun 21 15:22:43 mugge Adobe Photoshop CS4[24045]: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:43 mugge Adobe Photoshop CS4[24045]: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:43 mugge Adobe Photoshop CS4[24045]: CGContextDrawPath: invalid context
                                Jun 21 15:22:43 mugge Adobe Photoshop CS4[24045]: CGContextRestoreGState: invalid context
                                Jun 21 15:22:44 mugge Adobe Photoshop CS4[24045]: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:44 mugge Adobe Photoshop CS4[24045]: CGContextSaveGState: invalid context
                                Jun 21 15:22:44 mugge Adobe Photoshop CS4[24045]: CGContextSetLineCap: invalid context
                                Jun 21 15:22:44 mugge Adobe Photoshop CS4[24045]: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:44 mugge Adobe Photoshop CS4[24045]: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:44 mugge Adobe Photoshop CS4[24045]: CGContextBeginPath: invalid context
                                Jun 21 15:22:44 mugge Adobe Photoshop CS4[24045]: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:44 mugge Adobe Photoshop CS4[24045]: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:44 mugge Adobe Photoshop CS4[24045]: CGContextDrawPath: invalid context
                                Jun 21 15:22:44 mugge Adobe Photoshop CS4[24045]: CGContextRestoreGState: invalid context
                                Jun 21 15:22:45 mugge Adobe Photoshop CS4[24045]: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:45 mugge Adobe Photoshop CS4[24045]: CGContextSaveGState: invalid context
                                Jun 21 15:22:45 mugge Adobe Photoshop CS4[24045]: CGContextSetLineCap: invalid context
                                Jun 21 15:22:45 mugge Adobe Photoshop CS4[24045]: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:45 mugge Adobe Photoshop CS4[24045]: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:45 mugge Adobe Photoshop CS4[24045]: CGContextBeginPath: invalid context
                                Jun 21 15:22:45 mugge Adobe Photoshop CS4[24045]: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:45 mugge Adobe Photoshop CS4[24045]: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:45 mugge Adobe Photoshop CS4[24045]: CGContextDrawPath: invalid context
                                Jun 21 15:22:45 mugge Adobe Photoshop CS4[24045]: CGContextRestoreGState: invalid context
                                Jun 21 15:22:46 mugge Adobe Photoshop CS4[24045]: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:46 mugge Adobe Photoshop CS4[24045]: CGContextSaveGState: invalid context
                                Jun 21 15:22:46 mugge Adobe Photoshop CS4[24045]: CGContextSetLineCap: invalid context
                                Jun 21 15:22:46 mugge Adobe Photoshop CS4[24045]: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:46 mugge Adobe Photoshop CS4[24045]: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:46 mugge Adobe Photoshop CS4[24045]: CGContextBeginPath: invalid context
                                Jun 21 15:22:46 mugge Adobe Photoshop CS4[24045]: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:46 mugge Adobe Photoshop CS4[24045]: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:46 mugge Adobe Photoshop CS4[24045]: CGContextDrawPath: invalid context
                                Jun 21 15:22:46 mugge Adobe Photoshop CS4[24045]: CGContextRestoreGState: invalid context
                                Jun 21 15:22:47 mugge Adobe Photoshop CS4[24045]: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:47 mugge Adobe Photoshop CS4[24045]: CGContextSaveGState: invalid context
                                Jun 21 15:22:47 mugge Adobe Photoshop CS4[24045]: CGContextSetLineCap: invalid context
                                Jun 21 15:22:47 mugge Adobe Photoshop CS4[24045]: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:47 mugge Adobe Photoshop CS4[24045]: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:47 mugge Adobe Photoshop CS4[24045]: CGContextBeginPath: invalid context
                                Jun 21 15:22:47 mugge Adobe Photoshop CS4[24045]: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:47 mugge Adobe Photoshop CS4[24045]: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:47 mugge Adobe Photoshop CS4[24045]: CGContextDrawPath: invalid context
                                Jun 21 15:22:47 mugge Adobe Photoshop CS4[24045]: CGContextRestoreGState: invalid context
                                Jun 21 15:22:48 mugge Adobe Photoshop CS4[24045]: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:48 mugge Adobe Photoshop CS4[24045]: CGContextSaveGState: invalid context
                                Jun 21 15:22:48 mugge Adobe Photoshop CS4[24045]: CGContextSetLineCap: invalid context
                                Jun 21 15:22:48 mugge Adobe Photoshop CS4[24045]: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:48 mugge Adobe Photoshop CS4[24045]: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:48 mugge Adobe Photoshop CS4[24045]: CGContextBeginPath: invalid context
                                Jun 21 15:22:48 mugge Adobe Photoshop CS4[24045]: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:48 mugge Adobe Photoshop CS4[24045]: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:48 mugge Adobe Photoshop CS4[24045]: CGContextDrawPath: invalid context
                                Jun 21 15:22:48 mugge Adobe Photoshop CS4[24045]: CGContextRestoreGState: invalid context
                                Jun 21 15:22:49 mugge Adobe Photoshop CS4[24045]: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:49 mugge Adobe Photoshop CS4[24045]: CGContextSaveGState: invalid context
                                Jun 21 15:22:49 mugge Adobe Photoshop CS4[24045]: CGContextSetLineCap: invalid context
                                Jun 21 15:22:49 mugge Adobe Photoshop CS4[24045]: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:49 mugge Adobe Photoshop CS4[24045]: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:49 mugge Adobe Photoshop CS4[24045]: CGContextBeginPath: invalid context
                                Jun 21 15:22:49 mugge Adobe Photoshop CS4[24045]: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:49 mugge Adobe Photoshop CS4[24045]: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:49 mugge Adobe Photoshop CS4[24045]: CGContextDrawPath: invalid context
                                Jun 21 15:22:49 mugge Adobe Photoshop CS4[24045]: CGContextRestoreGState: invalid context
                                Jun 21 15:22:50 mugge Adobe Photoshop CS4[24045]: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:50 mugge Adobe Photoshop CS4[24045]: CGContextSaveGState: invalid context
                                Jun 21 15:22:50 mugge Adobe Photoshop CS4[24045]: CGContextSetLineCap: invalid context
                                Jun 21 15:22:50 mugge Adobe Photoshop CS4[24045]: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:50 mugge Adobe Photoshop CS4[24045]: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:50 mugge Adobe Photoshop CS4[24045]: CGContextBeginPath: invalid context
                                Jun 21 15:22:50 mugge Adobe Photoshop CS4[24045]: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:50 mugge Adobe Photoshop CS4[24045]: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:50 mugge Adobe Photoshop CS4[24045]: CGContextDrawPath: invalid context
                                Jun 21 15:22:50 mugge Adobe Photoshop CS4[24045]: CGContextRestoreGState: invalid context
                                Jun 21 15:22:41 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:41 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:41 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:41 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSaveGState: invalid context
                                Jun 21 15:22:41 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:41 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineCap: invalid context
                                Jun 21 15:22:41 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:41 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:41 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:41 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:41 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:41 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextBeginPath: invalid context
                                Jun 21 15:22:41 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:41 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:41 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:41 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:41 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:41 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextDrawPath: invalid context
                                Jun 21 15:22:41 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:41 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextRestoreGState: invalid context
                                Jun 21 15:22:42 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:42 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:42 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:42 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSaveGState: invalid context
                                Jun 21 15:22:42 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:42 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineCap: invalid context
                                Jun 21 15:22:42 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:42 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:42 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:42 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:42 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:42 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextBeginPath: invalid context
                                Jun 21 15:22:42 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:42 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:42 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:42 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:42 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:42 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextDrawPath: invalid context
                                Jun 21 15:22:42 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:42 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextRestoreGState: invalid context
                                Jun 21 15:22:43 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:43 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:43 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:43 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSaveGState: invalid context
                                Jun 21 15:22:43 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:43 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineCap: invalid context
                                Jun 21 15:22:43 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:43 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:43 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:43 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:43 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:43 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextBeginPath: invalid context
                                Jun 21 15:22:43 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:43 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:43 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:43 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:43 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:43 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextDrawPath: invalid context
                                Jun 21 15:22:43 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:43 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextRestoreGState: invalid context
                                Jun 21 15:22:44 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:44 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:44 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:44 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSaveGState: invalid context
                                Jun 21 15:22:44 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:44 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineCap: invalid context
                                Jun 21 15:22:44 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:44 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:44 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:44 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:44 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:44 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextBeginPath: invalid context
                                Jun 21 15:22:44 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:44 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:44 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:44 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:44 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:44 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextDrawPath: invalid context
                                Jun 21 15:22:44 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:44 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextRestoreGState: invalid context
                                Jun 21 15:22:45 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:45 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:45 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:45 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSaveGState: invalid context
                                Jun 21 15:22:45 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:45 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineCap: invalid context
                                Jun 21 15:22:45 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:45 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:45 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:45 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:45 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:45 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextBeginPath: invalid context
                                Jun 21 15:22:45 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:45 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:45 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:45 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:45 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:45 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextDrawPath: invalid context
                                Jun 21 15:22:45 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:45 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextRestoreGState: invalid context
                                Jun 21 15:22:46 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:46 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:46 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:46 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSaveGState: invalid context
                                Jun 21 15:22:46 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:46 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineCap: invalid context
                                Jun 21 15:22:46 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:46 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:46 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:46 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:46 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:46 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextBeginPath: invalid context
                                Jun 21 15:22:46 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:46 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:46 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:46 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:46 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:46 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextDrawPath: invalid context
                                Jun 21 15:22:46 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:46 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextRestoreGState: invalid context
                                Jun 21 15:22:47 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:47 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:47 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:47 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSaveGState: invalid context
                                Jun 21 15:22:47 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:47 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineCap: invalid context
                                Jun 21 15:22:47 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:47 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:47 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:47 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:47 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:47 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextBeginPath: invalid context
                                Jun 21 15:22:47 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:47 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:47 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:47 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:47 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:47 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextDrawPath: invalid context
                                Jun 21 15:22:47 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:47 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextRestoreGState: invalid context
                                Jun 21 15:22:48 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:48 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:48 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:48 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSaveGState: invalid context
                                Jun 21 15:22:48 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:48 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineCap: invalid context
                                Jun 21 15:22:48 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:48 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:48 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:48 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:48 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:48 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextBeginPath: invalid context
                                Jun 21 15:22:48 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:48 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:48 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:48 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:48 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:48 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextDrawPath: invalid context
                                Jun 21 15:22:48 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:48 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextRestoreGState: invalid context
                                Jun 21 15:22:49 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:49 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:49 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:49 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSaveGState: invalid context
                                Jun 21 15:22:49 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:49 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineCap: invalid context
                                Jun 21 15:22:49 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:49 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:49 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:49 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:49 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:49 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextBeginPath: invalid context
                                Jun 21 15:22:49 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:49 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:49 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:49 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:49 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:49 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextDrawPath: invalid context
                                Jun 21 15:22:49 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:49 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextRestoreGState: invalid context
                                Jun 21 15:22:50 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:50 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetStrokeColorWithColor: invalid context
                                Jun 21 15:22:50 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:50 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSaveGState: invalid context
                                Jun 21 15:22:50 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:50 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineCap: invalid context
                                Jun 21 15:22:50 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:50 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineJoin: invalid context
                                Jun 21 15:22:50 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:50 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextSetLineWidth: invalid context
                                Jun 21 15:22:50 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:50 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextBeginPath: invalid context
                                Jun 21 15:22:50 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:50 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextMoveToPoint: invalid context
                                Jun 21 15:22:50 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:50 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextAddLineToPoint: invalid context
                                Jun 21 15:22:50 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:50 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextDrawPath: invalid context
                                Jun 21 15:22:50 mugge [0x0-0x78078].com.adobe.Photoshop[24045]: Mon Jun 21 15:22:50 mugge.local Adobe Photoshop CS4[24045] <Error>: CGContextRestoreGState: invalid context
                                • 53. Re: Strange system log error from Photoshop CS4
                                  Level 7
                                  CS4 doesn't use those calls, so I'm betting it involved some system code (like open/save) or a third party plugin.
                                  • 54. Re: Strange system log error from Photoshop CS4
                                    MuggeGHQ Level 1
                                    Hi Chris.
                                    Thanks for your replay.
                                    plugin i understand but what do you mean by open/save ?
                                    I dont have any open/save problems from what i know of.
                                    • 55. Re: Strange system log error from Photoshop CS4
                                      Level 7
                                      The OS provided open and save dialogs could conceivably make those calls, as well as a third party plugin.
                                      You need to watch what you are doing when those errors appear (what dialog, what plugin, etc.).
                                      • 56. Re: Strange system log error from Photoshop CS4
                                        MuggeGHQ Level 1
                                        Alright.
                                        I now found out after updateing PS CS4 to 11.02 the Imagenomic Portraiture 2 gives this error, i think.
                                        It was the same errors i got in PS CS5 when i had the Portraiture 2 plugin installed (Even the new 64bit).
                                        But before 11.0.2 i didn't get this error in CS4 but now with 11.0.2 i do.
                                        So both PS CS4 and CS5 now gives this kind of error when any Imagenomic plugin is installed.
                                        Strange... and sad because i use both Portraiture 2 and Noiseware 4 Plug-in from Imagenomic and now
                                        i cant anymore because the log files gets op to 5-50MB every day when installed.
                                        Guess something in PS4 11.0.2 update changed something that CS5 have also have because it never
                                        happen in PS CS4 11.0.1.
                                        Alright then maybe i should message Imagenomic with the information.
                                        I will report back if the error starts again but i dought it after i removed it...
                                        Thx Chris
                                        • 57. Re: Strange system log error from Photoshop CS4
                                          If the plug in was not updated for 11.0.2 then the plug in developer obviously fell behind.
                                          It is sad that this plug in if it is as useful as you indicate was not quickly updated to work properly with the host application.
                                          But it is the plug in developers responsibility.
                                          • 58. Re: Strange system log error from Photoshop CS4
                                            Level 7
                                            11.0.2 shouldnt' need any plugin updates - the changes were minor.
                                            • 59. Re: Strange system log error from Photoshop CS4
                                              MuggeGHQ Level 1
                                              Hi.
                                              Yea Zimmerman. Your right.
                                              Its the developers that makes the mess here.
                                              It worked alright with the version before but the new Potraiture v2 updated plugin gives all the erros.
                                              I could live with it but the error file gets preatty big after some time.
                                              It grows and grows.
                                              • 60. Re: Strange system log error from Photoshop CS4
                                                EJ Printer Level 1
                                                MuggeGHQ, interesting that you have put the blame on developers. Here you have both CS4 and cs5 on your system, an older version of the OS, seemingly one system that works and one that doesn't and the developer is the cause? Which one? Why?
                                                • 61. Re: Strange system log error from Photoshop CS4
                                                  Mario Cajina
                                                  I'm getting the same error, this is the string that keeps repeating in the Mac OS X console log:
                                                  8/18/11 2:44:03 PM    Adobe Photoshop CS4[2487]    Adobe Photoshop CS4(2487,0xa02aa540) malloc: *** mmap(size=17002496) failed (error code=12)
                                                  8/18/11 2:44:03 PM    [0x0-0x9a09a].com.adobe.Photoshop[2487]    Adobe Photoshop CS4(2487,0xa02aa540) malloc: *** mmap(size=17002496) failed (error code=12)
                                                  8/18/11 2:44:03 PM    [0x0-0x9a09a].com.adobe.Photoshop[2487]    *** error: can't allocate region
                                                  8/18/11 2:44:03 PM    [0x0-0x9a09a].com.adobe.Photoshop[2487]    *** set a breakpoint in malloc_error_break to debug
                                                  8/18/11 2:44:34 PM    ReportCrash[4438]    Saved crash report for Adobe Photoshop CS4[2487] version 11.0.2 (11.0.2x20100519 [20100519.r.592 2010/05/19:02:00:00 cutoff; r branch]) (11.0.2) to /Users/me/Library/Logs/DiagnosticReports/Adobe Photoshop CS4_2011-08-18-144434_me-27.crash
                                                  8/18/11 2:44:39 PM    ReportCrash[4438]    Failed to relaunch /Applications/Adobe Creative Suite 4/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/MacOS/Adobe Photoshop CS4 - LSOpenApplication returned error: -600!
                                                  Here's the actual Adobe Photoshop CS4 crash log at pastebin.com: http://pastebin.com/LtbpRkLw
                                                  • 62. Re: Strange system log error from Photoshop CS4
                                                    Level 7
                                                    The malloc warning just means that Photoshop wants more RAM than is available. It's not an actual error, but could be related to the crash.
                                                    The crash is due to a corrupt font or a corrupt OS font cache.
                                                    Most of the tips in http://kb2.adobe.com/cps/843/cpsid_84363.html  also apply to CS4.
                                                    1 2 Previous Next
