My project started out being named after the product. Since then, we have rebranded the product for a different customer so I have 2 versions of the help, using conditional build tags to create the different output.
The Project Title needs to show the product name so when I create the webhelp output for each customer, I change the title accordingly in File>Project Settings. This changes the browser title to show the correct product name.
But I have realised that the main .htm file which is used to launch the webhelp still has the original name and this is displayed in the URL bar of the browser and also in the tooltip that displayes when the user hovers on the browser tab.
How can I change this filename? I will need to change it every time we do a release as each release needs a version for both customers.
Hi there
To change the file name of the WebHelp Start Page, you edit the properties of the Single Source Layout you are using.
Normally when I facilitate a RoboHelp HTML class, I advise folks that always naming the file Index.htm is a good habit to have.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
Hi Rick, it's not the name of the start page that is showing in the tooltip and URL. I don't really know what it is except that it's a .htm file in the project folder named the same as the .glo, .hhc, hhk, lng etc.
I've attached an image to try to explain what I mean. MACRO3Help was the original name of the project.
Hi there
Please post a screen capture of the following.
Right-click the WebHelp Single Source Layout and capture the dialog. What do you see listed in the field at the top of the dialog?
Cheers... Rick
I have two webhelp layouts, one for each product. The Project Name in the properties dialog is either agCapture4Help or MACRO4Help but never MACRO3Help. I entered this information manually for each layout.
Hello again
Okay, my bad. I see you are using WebHelp PRO. And that's a totally different thing than just WebHelp.
So are you publishing this to the RoboHelp Server? If not, WebHelp PRO is not the output you need to be using. It is only intended to work in concert with RoboHelp Server. We see lots of folks that see the word "PRO" and mistakenly conclude that it just has to be what they want, because if WebHelp is good, then WebHelp PRO just HAS to be all that and a bag of chips. So they gravitate right to it.
If you really are using RoboHelp Server, I'll have to leave it at this point for another person to answer or help with. I don't have that sort of setup to play with, so I'm pretty useless with that output type. Sorry.
Cheers... Rick
Oh gosh, I hadn't even realised there were two types of webhelp. And no I'm not using the RH server.
So I have just created a standard Webhelp output and it all works fine.
Thank you SO much.
Helen
