Consuming axis webservice works in ColdFusion 8, not in ColdFusion 7 - same exact code
Apr 28, 2008 Apr 28, 2008
I have the same CFML code that I used to invoke a webservice in ColdFusion 8 that works fine.
I think it's a java version related issue (ColdFusion 7 uses JDK 1.4, ColdFusion 8 uses JDK 1.6).
When I deploy this in a ColdFusion 7 server, I get an illegal argument exception:
Could not perform web service invocation "insertUpdateDnbCompany".
Here is the fault returned when invoking the web service operation:
java.lang.IllegalArgumentException: argument type mismatch
Here's the stack trace:
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at coldfusion.xml.rpc.ServiceProxy.invokeImpl(ServiceProxy.java:223)
at coldfusion.xml.rpc.ServiceProxy.invoke(ServiceProxy.java:153)
at coldfusion.runtime.CfJspPage._invoke(CfJspPage.java:1634)
at cfReplicate22ecfm975370412.runPage(E:\Inetpub\wwwroot\webapps_NEW\MDM\Replicate2.cfm:11)
at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:152)
at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:349)
at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:225)
at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:51)
at coldfusion.filter.PathFilter.invoke(PathFilter.java:86)
at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:69)
at coldfusion.filter.BrowserDebugFilter.invoke(BrowserDebugFilter.java:52)
at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28)
at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at coldfusion.filter.RequestThrottleFilter.invoke(RequestThrottleFilter.java:115)
at coldfusion.CfmServlet.service(CfmServlet.java:107)
at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:78)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:257)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:541)
at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:204)
at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:318)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:426)
at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:264)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
Advanced techniques
337
You should start by changing this line and all dependant lines from:
request = structNew();
to:
req = structNew(); or variables.request
Request is a build in scope and should not be used this way. Changing this very well cause this to function in both CF7 and CF8 since it after introspecting the request and struct types some significant restructuring of the underlying java classes. Inorder to help any more I would need to see the wsdl.
HTH
-Jason
I'll try to prepend my request struct with the variables prefix and see if it resolves the issue. But this is why I called my struct request.
I changed my struct to be called 'req' instead of request and it worked! I guess it doesn't matter that it's named different from my .wsdl.
Documentation
