Hi everyone,
I've set my Internet Explorer to ignore those security messages showing up everytime I test drive a new WebHelp build.
But of course this could cause some trouble on the client's side.
I there a certain setting in RH(8) which helps avoid those alerts in IE?
Thanx a lot.
Paul
Those messages are because you are probably running the webhelp locally. Your help is designed to be run from a server so when it is installed at a client site on a server, they will not get those messages. You can avoid it by publishing to a server in your environment or changing your IE settings or including Mark of the Web (see the wizard).
