1. Re: Dreamweaver interface - outline font
SnakEyez02 Feb 25, 2010 4:34 PM (in response to broomeGirl)I've seen this occur on a Mac before. The font that shows up will vary. The culprit is always a corrupted font file. If you go into the Font Book you should be able to determine the font and remove it and it should go back to normal.
2. Re: Dreamweaver interface - outline font
broomeGirl Feb 25, 2010 6:06 PM (in response to SnakEyez02)Wow! How lucky am I that you saw this question? I have 649 fonts in my fonts directory in my hd library, they are a mixture of mac and windows fonts as I use parallels to operate windows on my mac. I scrolled through them and couldnt find a "corrupted one" .. sorry for appearing stupid but how do you find the corrupted one? Thanks so much for your time.
3. Re: Dreamweaver interface - outline font
SnakEyez02 Feb 26, 2010 6:07 AM (in response to broomeGirl)In Font Book cmd+a to select all, then File->Validate Fonts. Delete anything that does not validate. Another quick solution will require a better quality screenshot than what you posted and some cropping, the WhatTheFont tool will usually match up the font as well: WhatTheFont! « MyFonts .
Also your Windows fonts should not be in that Font Book at all. They should be contained within the virtual environment or within the partition with Windows depending on your setup. If they are contained in the Font Book they should really be separated out in there.
4. Re: Dreamweaver interface - outline font
broomeGirl Feb 26, 2010 6:12 AM (in response to SnakEyez02)Thank you very much .. i will have a look at the sites and the command you have suggested and also try to separate my fonts.
5. Re: Dreamweaver interface - outline font
LRImages May 24, 2010 10:40 PM (in response to broomeGirl)i'm having trouble and it's specifically THAT FONT.
with CS5 though - what did it for you in the end?
-Louis
UPDATE: while i was unable to find the font at fault using Apple's Font Book, I downloaded an apparently free version of linotype font explorer 1.2.3 last night. Though it's an old program (had plugins for CS3 and CS2 applications (!) ) it displayed an unnamed (or unrecognized) font with a number of question marks. A truetype font, style also had question marks as placeholders. Just sort by name or style and you should be able to find it at or near the top of your list.
Message was edited by: LRImages
6. Re: Dreamweaver interface - outline font
echopeus Jan 25, 2011 9:44 PM (in response to LRImages)the font that i found was my error was file named b5hollow
remove all files of this name and problem gone
7. Re: Dreamweaver interface - outline font
k_the_buster Mar 21, 2012 7:43 AM (in response to broomeGirl)I've been having exactly the same problem. I validated all fonts in Fontbook and deleted any fonts that had errors or even warnings. I then went back through my list of fonts in Fontbook and deleted any duplicate fonts.
b5hollow is not on my list btw.
What the font didn't bring me any luck either.
8. Re: Dreamweaver interface - outline font
jimmyuisken Jun 24, 2012 1:18 AM (in response to k_the_buster)Hey Guys,
I've been having the same problem though when i try to delete duplicates/errored fonts my Mac is freaking out and jsut giving me the wee spinning rainbow kaleidiscope thingy (working mouse icon). I've over 3000 fonts - 964 minor problems, 176 with serious errors. Anyway i can get Font Book to push this through?
Cheers
Jim
9. Re: Dreamweaver interface - outline font
SnakEyez02 Jun 24, 2012 6:54 AM (in response to jimmyuisken)jimmyuisken wrote:
Hey Guys,
Cheers
Jim
Jimmy, Fontbook is ok for basic management, but for that many fonts you really need to consider an investment in Font Management. There are plenty of tools out there from FontExplorerX Pro, to Suitcase Fusion, and FontAgent Pro. Personally I use FontExplorerX Pro without any issues. Works great with most of the Adobe suite, but no plugins for DW or Fireworks, but ID, PS and Illustrator work just fine.
