1. Re: Snippets not showing
Sqrlz Feb 13, 2010 11:20 AM (in response to DJoel1226)Same thing here - they are no longer "docked" in the pane on the left. BUT I can access them by clicking on "view/resource windows/snippets" Anyone know how to get them docked again?
2. Re: Snippets not showing
Roy Reed Feb 18, 2010 8:16 AM (in response to Sqrlz)Right-click in a blank area of the undocked snippets window and select 'Move Snippets to > Top/Bottom/Left/Right'.
3. Re: Snippets not showing
Sqrlz Feb 18, 2010 9:30 AM (in response to Roy Reed)Hi that does not work for me - I can dock all other resource windows.
When I right click on snippets I have no option for docking it - I have right clicked in every possible location.
This has only been the last month or so that this behavior has happenned. I am thinking I might need to uninstall and reinstall homesite.One day all docked resources wers undocked... I was able to re-dock all other resource windows... just not snippets.
But thanks!
Oh how I wish this application would be revived!
Deb
4. Re: Snippets not showing
edavis7110 Feb 26, 2010 9:16 AM (in response to DJoel1226)I found that if you modify your registry settings that you will be able
to re-dock the snippets.
BACK UP YOUR REGISTRY BEFORE ATTEMPING THIS!!!!
I have had the same issue and found that this is the only tab that has no clear cut way of docking in Homesite.
I looked at the registry and compared it to the tabs and here is what I came up with:
Path = HKEY_CURRENT_USER>Software>Macromedia>Homesite+>Docking>frmDockSnippets
Here is what should be in there:
(Default) REG_Z (value not set)
AlwaysOnTop REG_Z 1
DockHost REG_Z AllaireTabDockForm0
DockTab REG_Z 0
Floating REG_Z 0
PageIndex REG_Z 5 (note this has to be a number not already in use, be sure to check your other tabs and then use the next available)
Position REG_Z 0,0,434,979 (note all tabs will have the same value, depending on your set up my numbers may or may not match yours but be sure to check the other tabs and use those values)
Visible REG_Z 1
I hope this helps, I could not find an answer anywhere and found that this worked for me.
