1. Re: Layer Question
Wade_Zimmerman Feb 26, 2010 11:22 AM (in response to dcacrobat)Turn the Map into a symbol and say call it Map in the sybols panel.
Now open the the three d effect from the appearance panel, you select the object with the three d effect and then double click the effect in the appearance panel.
The three d effect dialog opens where it says Map Art you click to open up the map art section turn on preview and you then select the planes you want to map the art to.
then you select the symbol from the symbol drop down.
Now the lining up of the symbol is a little tricky and requires some judgment and visual skills, when satisfied click Ok.
There is a more manual way if this does not work for you.
2. Re: Layer Question
Kurt Gold Feb 26, 2010 11:27 AM (in response to Wade_Zimmerman)Probably this instruction will not work in AI 9.
3. Re: Layer Question
dcacrobat Feb 26, 2010 4:47 PM (in response to Kurt Gold)Much thanks for your timely response. I created the 3D type effect by copying identical text and arragning them one in front of the other. The features suggested in the other reply do not exist in version 9.0. If you have a proposed solution it would be appreciated.
4. Re: Layer Question
Wade_Zimmerman Feb 26, 2010 10:51 PM (in response to dcacrobat)I see…OOps!
In that case you will have to do it manual way but you are not going to like this.
It requires you to bring the art into photoshop and use Vanishing point.
And I realize if you have Illustrator 9 then you probably have an older version of Photoshop
Actually now that I think of it there is no realistic way of wrapping a map around three d letters since it is a continuos art on a flat surface once you cut it and fold it it is no longer continuous but since it has to accommodate the letters returns the continuum is broken it there fore can not realistically be mapped. You simply run out of info.
So the best you can do is map the art to the face and fake the art on the returns.
5. Re: Layer Question
Jacob Bugge Feb 27, 2010 3:50 AM (in response to dcacrobat)dcacrobat,
There may be different solutions, possibly without Photoshop, depending on the desired appearance. An image/screenshot might help the helpers.
