16 Replies Latest reply on Feb 27, 2010 10:42 AM by paul-dall
    Beginner question - please help
    brit chic
      Can anyone please tell me how to remove the margin of space at the very top of my website? I would like to align the site to the very top and eliminate the grey background strip. Thanks...
      http://www.houndsonholiday.ca/
        • 1. Re: Beginner question - please help
          brit chic Level 1
          I have looked up faq but don't know how to phrase the question appropriately
          • 2. Re: Beginner question - please help
            paul-dall Level 1
            HI! Your problem is probabably the class that you assigned to your body tag.
            .thrColFixHdr #footer p {
                 margin: 0; /* zeroing the margins of the first element in the footer will avoid the possibility of margin collapse - a space between divs */
                 padding: 10px 0; /* padding on this element will create space, just as the the margin would have, without the margin collapse issue */
            <body class="thrColFixHdr">
            either change the style to:
                 margin: 0; /* padding on this element will create space, just as the the margin would have, without the margin collapse issue */
                 padding-top: 0px;
                 padding-right: 0;
                 padding-bottom: 10px;
                 padding-left: 0;
            or create a new style for the body.
            Paul
            • 3. Re: Beginner question - please help
              brit chic Level 1
              thanks... I did what you suggested, and the space at the top disappeared in
              dreamweaver but when I pressed f-12 there was still the grey space at the
              top in explorer... am I missing something?
              thanks for replying btw
              • 4. Re: Beginner question - please help
                paul-dall Level 1
                Did you clear you cache in IE? And then reload
                Paul
                • 5. Re: Beginner question - please help
                  paul-dall Level 1
                  If it does not work in IE when you clear the browser cache and refresh then
                  try this.
                  Paul
                  • 6. Re: Beginner question - please help
                    brit chic Level 1
                    No it didn't work... try what?
                    • 8. Re: Beginner question - please help
                      paul-dall Level 1
                      HI! Add the following into you body tag.
                      cellpadding="0" cellspacing="0" margin="0"
                      body should look a bit like this
                      NOTE: It could also be your header style.
                      I am testing it out now. Try the above in the meantime.
                      Paul
                      • 9. Re: Beginner question - please help
                        paul-dall Level 1
                        HI! I got it, Your main container and header have been vertically align top.
                        And I also played a bit with your borders.
                        Just copy and paste it.
                        body
                        .thrColFixHdr #container
                        .thrColFixHdr #header {
                             background-color: #FFFFFF;
                             vertical-align: top;
                             margin: 0px;
                             padding: 0;
                             border: 1px solid #FFFFFF;
                        .thrColFixHdr #header h1
                        .thrColFixHdr #sidebar1
                        .thrColFixHdr #sidebar2
                        .thrColFixHdr #mainContent {
                             margin-top: 0;
                             margin-right: 200px;
                             margin-bottom: 0;
                             margin-left: 200px;
                             padding-top: 0;
                             padding-right: 10px;
                             padding-bottom: 0;
                             padding-left: 10px;
                        .fltrt { /* this class can be used to float an element right in your page.
                        The floated element must precede the element it should be next to on the
                        page. */
                             float: right;
                             margin-left: 8px;
                        .fltlft { /* this class can be used to float an element left in your page */
                             float: left;
                             margin-right: 8px;
                        .clearfloat { /* this class should be placed on a div or break element and
                        should be the final element before the close of a container that should
                        fully contain a float */
                             clear:both;
                            height:0;
                            font-size: 1px;
                            line-height: 0px;
                        .style3
                        .style4 {
                             font-size: 11pt
                        .style12 {font-size: 27px}
                        .style13 {font-size: 11pt; font-weight: bold; }
                        .main_table
                        </style
                        • 10. Re: Beginner question - please help
                          brit chic Level 1
                          Thank you guys so much for your help and advice, I had to go to bed to get
                          up with my two year old daughter. Will have a go at fixing it at her
                          naptime. Thanks again...
                          • 11. Re: Beginner question - please help
                            brit chic Level 1
                            Hi Paul...
                            I pasted the code in to replace from line 11 (body) to line 129 (</style)
                            and it changed everything including my side margins disappeared so I CTRL>Z
                            and put it back
                            Am I pasting it in the wrong place? Or should I be pasting the individual
                            pieces of it into each section
                            I also tried the other suggestions about padding and the grey strip is there
                            Thanks..
                            • 12. Re: Beginner question - please help
                              brit chic Level 1
                              I started another template to see when the space occurred, and it seemed to
                              occur after I put in the logo and HoundOn Holiday name and then pressed
                              enter to create more space under them to put in the menu bar. It was
                              pressing the enter key to make space for the horizontal menu bar that did it
                              Can't seem to undo it without deleting the logo and biz name.
                              • 13. Re: Beginner question - please help
                                hans-g. Adobe Community Professional & MVP
                                Hi Brit,
                                could you solve the problem already of yourself? Because the only difference between
                                http://www.houndsonholiday.ca/ (no space)
                                http://www.houndsonholiday.ca/Copy%20of%20index.htm (little space)
                                I can see is a little free white space below your frame with the links. The gray strip, I can't find.
                                Hans-G.
                                • 14. Re: Beginner question - please help
                                  paul-dall Level 1
                                  HI! No its all in the header.
                                  The code is css style so its always in the header.
                                  I inserted the whole page for you but NOTE: Don’t copy the whole page to
                                  your sheet because this is only a generated source copy that I have so other
                                  things are missing ( like flash and images ) so only look at where I
                                  inserted the css style in the header.
                                  Paul
                                  **********HTML Code**************
                                  <!-- TemplateBeginEditable name="head" ><! TemplateEndEditable -->
                                  body
                                       margin: 0px;
                                       padding: 0;
                                       margin-top: 0;
                                       margin-bottom: 0;
                                       margin-left: 200px;
                                       padding-top: 0;
                                       padding-bottom: 0;
                                       padding-left: 10px;
                                  page. */
                                       float: right;
                                       margin-left: 8px;
                                       float: left;
                                       margin-right: 8px;
                                       clear:both;
                                      height:0;
                                      font-size: 1px;
                                      line-height: 0px;
                                  .style3
                                  .style4 {
                                       font-size: 11pt
                                  .main_table
                                  /* place css box model fixes for IE 5* in this conditional comment */
                                  </style>
                                  <![endif]><![if IE]>
                                  /* place css fixes for all versions of IE in this conditional comment */
                                  .thrColFixHdr #sidebar2, .thrColFixHdr #sidebar1 { padding-top: 30px; }
                                  /* the above proprietary zoom property gives IE the hasLayout it needs to
                                  avoid several bugs */
                                  Specialized Pet Care For Your Furry Tail Vacations
                                  We “get it”!... Leaving your pet leaves you WORRIED!
                                  Hounds On Holiday has raised the bar for dog care
                                  with the first truly guilt-free and cage-free boarding alternative for the
                                  discriminating pet lover. We’ll love your pet like you do!
                                  With Hounds On Holiday, never again will you have to
                                  feel guilty when you need to be away from your dog! No longer does dog
                                  boarding need to mean jail-like facilities of bars, concrete and isolated
                                  runs.
                                  Our professional home-from-home pet care service has
                                  been specifically designed for pet owners who are unable or unwilling to use
                                  traditional forms of kenneling, and who feel insecure or uncomfortable
                                  allowing strangers into their home to care for their pets.
                                  To learn more about using our home-from-home pet care
                                  service as an alternative to kennels or to find out more about becoming one
                                  of our host families, please contact us. We may all be crazy about dogs, but
                                  you’ll discover that Hounds On Holiday really makes perfect sense.
                                  Become A Host Or Host Family
                                  Hounds On Holiday is currently seeking loving hosts
                                  and host families.
                                  We’ve all been there. If you have dogs, and you
                                  just can’t leave them in boarding kennels or impose on your family or
                                  friends once again, what do you do?..
                                  And if you love having a dog around but you find you
                                  can’t take on the full-time responsibility of ownership – again, what do you
                                  do?
                                  What we did was to set up our home-from-home complete
                                  pet care service, including collection and delivery to ensure parting is
                                  less stressful for you and your pet.
                                  Many of our pre-screened host families are active retired people who
                                  enjoy the com-panionship and flexibility of caring for their welcomed
                                  house-guest.
                                  Alternatively, our hosts may be home during the day
                                  with children or pets of their own, and a visiting dog compliments their
                                  existing situation perfectly.
                                  *To become a host you must be home full time, but not
                                  24/7 (hosts may not leave the dog 8 -12 hrs/day for a job but short absences
                                  are fine).
                                  <span class="style12">Site Under Development</span><br />
                                  For more information, please contact:
                                  Telephone: *519-835-5588*
                                  Email: *info@houndsonholiday.ca*
                                  *The Unique Alternative To
                                  Kennels*
                                  !big-dog.jpg|height=176|alt=Home Page Image|width=352|src=big-dog.jpg|border=3!
                                  Our Service:
                                  A superior alternative to dog boarding kennels, Hounds
                                  On Holiday provides a home from home holiday for your dog. The concept is
                                  a new kind of dog-sitting service designed to offer pet owners peace of mind
                                  when they travel away from home.
                                  Dog kennels, dog boarding houses and pet sitters
                                  cannot compete with our unique private-home services that offer cosy,
                                  cage-free environments with around-the-clock, one-on-one human contact with
                                  their loving hosts. Unlike a kennel or boarding house, our service also
                                  prevents exposure to a host of diseases and illnesses.
                                  We arrange for dogs to stay with loving host families
                                  who can match the sort of environment and routine the dogs are used to.We
                                  select the ideal dog sitting host family from our portfolio of trusted dog
                                  sitters who meet our extremely high standards.
                                  Accommodation is arranged in a warm, friendly home
                                  environment similar to your own. Exercise and feeding routines are
                                  maintained just as your dog is used to, he can even take his own bed and
                                  toys! There are no hidden charges in our rates for play time, cuddles or
                                  walking.
                                  To learn more about using our home-from-home dog
                                  sitting service as an alternative to kennels, or to find out about
                                  becoming one of our host family dog sitters offering dog holidays, please
                                  call: 519-835-5588
                                  or email: info@houndsonholiday.ca
                                  *************End of HTML Code *************
                                  • 15. Re: Beginner question - please help
                                    brit chic Level 1
                                    I deleted the logo and title and then re-inserted them and fixed the grey
                                    strip.... yay
                                    I will still go through the code and see what changes you made to border
                                    etc...
                                    thanks again
                                    http://www.houndsonholiday.ca/copyindex.html
                                    Gaynor
                                    • 16. Re: Beginner question - please help
                                      paul-dall Level 1
                                      HI! Glad you got it working
                                      Paul
