Installing CF8 multi-server on a Dell PowerEdge server (64
bit) running Linux Redhat Enterprise V5
Installed XAMPP for Linux 1.6.6 (Apache 2.2.8, etc.)
After running /opt/jrun4/bin/cf-connector.sh all goes well
and the new module mod_jrun22.so is built and included into
Apache's startup file httpd.conf, but when Apache attempts to
restart, get the message below (the last few lines of
cf-connector's log file at /opt/jrun4/Connectorinstall.txt).
I have tried both the 32- and 64-bit versions of CF8, I've
tried running wsconfig directly using the -ws32 switch. I now have
about 25 copies of httpd.conf!!!
If I understand the error correctly, mod_jrun22.so is being
built as a 64-bit object and httpd is needing a 32-bit object.
I have examined every instance of LD_LIBRARY_PATH in the
source and build files to see if there is a 64-bit library
referenced and haven't found any.
I'm really hoping someone out there knows what I need to do
to fix this.
Thanks in advance!
Dan Parchman, IT Technician
Juniper Systems, Inc.
www.junipersys.com
Error message:
