Show 4 replies
1. Re: Removing White Space in Code Formatting
Newsgroup_User Apr 30, 2008 2:24 AM (in response to thanser)thanser wrote:
> My question is, does anyone know of a way to select a page-full of source
> code, and apply a command to REMOVE all of the nice white space, indents, etc,
> to fix these gaps that appear in IE? I'm only selecting the code within the
> body tags.
I'm not sure but perhaps with find and replace, using a regular
expression? I'm not very good at regex though, so can't go into more
detail about it.
> It's getting to be a pain selecting and backspacing the white spaces within
> this code. What a joke.
I bet!
> Ironically, I've been making sites using layout tables for ten years now, and
> I've never had a problem with it in IE like I do presently.
Perhaps after 10 years it is time to abandon layout tables and embrace
the very popular method of laying out your content using CSS
Positioning. It's not without its difficulties in trying to get designs
to appear the same cross-browser, but your html code will be infinitely
cleaner and more efficient. -
2. Re: Removing White Space in Code Formatting
Newsgroup_User Apr 30, 2008 4:05 AM (in response to thanser)> Can anyone suggest a work around to remove the white spaces within table
> code,
> to eliminate the gaps that appear in IE?
Whitespace in code *can* cause this, but most often it does not.
Frequently, these gaps are caused by the appearance of a failure to collapse
the default margins around an element in a cell. We would really need to
see your code to know why you are getting them.
In addition, your use of "layout tables" troubles me and may be at the root
of what is troubling you. If you are using Layout Mode to create these
tables, then read on.
In my opinion, there are three serious problems with Layout Mode -
1. Perhaps most importantly, it sits between you and *real* HTML tables,
and fools you into believing that concepts like "layout cell" and
"autostretch" really mean something. They do not. As long as you use
Layout Mode, you'll never learn one of the most important things for new web
developers - how to build solid and reliable tables.
2. Actually, #1 wouldn't be *so* bad, except that the code that is written
by Layout Mode is really poor code. For example, a layout table contains
MANY empty rows of cells. This can contribute to a table's instability.
In addition, if your initial positioning of the table's cells is a bit
complex,
Layout Mode will throw in col- and rowspans aplenty as it merges and splits
cells willy-nillly to achieve the pixel-perfect layout you have specified.
Again,
this is an extremely poor method for building stable tables, because it
allows
changes in one tiny cell's shape (i.e, dimensions) to ripple through the
rest
of the table, usually with unexpected and sometimes disastrous consequences.
This is one of the primary reasons for the final result's fragility - read
this -
http://apptools.com/rants/spans.php
3. The UI for Layout Mode is beyond confusing - many options that you might
want to use are inaccessible, e.g., inserting another table, or layer onto
the page.
I can understand the new user's desire to use this tool to make their life
easier,
but the cost is just too heavy in my opinion.
To make good tables, keep it simple. Put a table on the page, and begin to
load your content. If you would want a different table layout, instead of
merging or splitting cells, consider stacking tables or nesting simple
tables instead, respectively.
And above all, do not try to build the whole page with a single table!
Luckily, Adobe understands the problems created for the unsuspecting user
who falls into this trap, and has elected to remove this feature altogether
from the next version of DW. The time is right for you to begin working
with tables properly!
To read more about this approach, visit the DW FAQ link in my sig, and run
through the table tutorials.
Murray --- ICQ 71997575
Adobe Community Expert
(If you *MUST* email me, don't LAUGH when you do so!)
http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
http://www.dwfaq.com - DW FAQs, Tutorials & Resources
"thanser" <webforumsuser@macromedia.com> wrote in message
news:fv8qkc$5a8$1@forums.macromedia.com...
> The dreaded gaps in IE that appear in layout tables is causing me
> headaches on
> a site I'm working on right now, and I'm finding that removing all of the
> nice,
> neat, orderly source code formatting that DW adds so well solves the
> problem.
> etc,
> the
> body tags.
> within
> and
> code,
> Thanks.
3. Re: Removing White Space in Code Formatting
thanser Apr 30, 2008 11:54 AM (in response to Newsgroup_User)Thanks, both of you.
Removing the code formatting from a document (besides creating code "spew" that is impossible to read) is a poor fix for these gaps in IE, for sure. I'm reluctant to keep doing this.
Ironically, the PhotoShop/ImageReady slice-and-dice method of generating HTML pages with tables works perfectly fine, no gaps in IE.
I'm not using layout mode in DW, no. I've yet to even mess with it. The original HTML file began as an output from ImageReady, if I recall correctly.
Additionally, I HAVE begun implementing CSS DIV containers and styles for a few years now. I guess I inherently design things that I know I can hold together with a table and cells, but I should be smarter about using DW and using tables. And using CSS positioning, too!
A nested table: I can remember when this was verboten, and not supported by some earlier browsers. Now it's normal practice.
The site I'm currently working on is here:
http://www.tomhanser.com/texas
Thanks again.
4. Re: Removing White Space in Code Formatting
Newsgroup_User Apr 30, 2008 2:59 PM (in response to Newsgroup_User)> Ironically, the PhotoShop/ImageReady slice-and-dice method of generating
> HTML
Actually not. Any wizard produced fragile HTML that breaks in unexpected
ways as soon as you begin to add content. People who use this 'perfectly
fine' method of creating web pages account for about 50% of the posts here
on this forum.
Slicing and dicing in Photoshop or Fireworks is functionally equivalent to
everything (almost) I said about Layout mode.
> by
Nested tables have always been supported *and* proper to use, but one had to
know how to use them. The easiest way to 'poison' a nested table layout was
to slice and dice exactly the way that PS/IR/FW does.
Your particular page is going to have problems because a) you do not have a
doctype specified on the page, b) you have used XHTML-type tag syntax
there -
<area shape="rect" coords="45,167,202,182" href="about.html" />
I recommend that you open this page in DW, and use FILE | Convert > HTML
4.01 Transitional. That will take care of both of those problems.
news:fvaf96$11b$1@forums.macromedia.com...
> I'm
> HTML
> correctly.
> a
> and
> by
> Thanks again.
