I try to create CAI by captivate3. The project contain
1. 10 items pre-test
2. Lesson
3. 10 items post-test
My problem is I cannot separate in post-test from the pre-test. That is when I insert 10 items multiple choice post-test after lesson, Quiz result slide will automatically after the post - test slide and then make it 20 items.
I want to separate the pre-test's quiz result slide from the post-test's.
How can I operate it?
Thanks a lot
Hello,
It will be necessary to have the pre- and post-test in different files to have the results separately. With CP4 it could be possible to have a solution in the same file, using variables and advanced actions, but that is not possible in CP3.
Lilybiri
Could you please explain me step by step?
I apologize but I just learn about this. I need more detail step by step so that I can follow it. Thanks a lot.
Which version of CP do you use?
I mean that you create a CP-file with the pre-test, it will then report the score for this test OK.
Make a second file for your lesson, eventually you can add the post-test in this same file and it will report the score of this post-test. Or you create the post-test in a third file.
You will have to chain them together: in CP4 you can use the Aggregator, or you make a short CP-file functioning as a sort of menu in which you put links to the three (or two) other files.
Hope this makes sense (what is your native language?)
Lilybiri
Hi Lilybiri
I'm Thai. I use cp4. I'm not sure you understand my poor English or not?
Anyway, I followed your advise to make 3 files as follows:
First --> pre-test + Lesson
Second --> post- test
Third --> Main menu
For the main menu, I made a button to link to pre-test and post-test by choosing
"open url or file" I can preview this in my computer but I can't preview the link (pre-test and post-test) in
another computer.
Could you provide me software simulation step by step?
Thank you
Hello,
I'm not a native English speaker myself, hope I did not hurt you by asking. It is not easy to explain in another language, sometimes I could help in another language but Thai, no that is not possible at all; was in Thailand long ago, very kind people.
About your question: first of all, did you install the update for CP4? Open the menu Help, choose Updates.
In 'Open URL or File' you need to have a relative path, this means only the file name, no indication like c:\MyDocuments\My Adobe Captivate Projects\... Just delete that part. Or, instead of browsing for the file (using the ellipsis '...') type only the file name (CP-file) in.
Be sure to have the 3 files in the same folder. When publishing you need to have them in the same folder too.
Hope you can understand what I tried to explain.
Lilybiri
