Learn about Edge Delivery Services in upcoming GEM session
SOLVED
How to complete process with event listening inside
Avatar
Former Community Member
Hi all,
I have a workflow, a part of it contains a branch gate way:
Branch 1: Wait point (7 days)
Branch 2: Listening event
If after 7 days and no event is sent, the workflow auto emails user and closes
Oherwise it will route to another user.
I observe that if event is received, then at the end the process status can be COMPLETE. But if after 7 days and no event is received, after last user complete the form, the process status is still RUNNING.
I'm thinking about this approach: adding 1 sending event after wait point in branch 1, it send an event so that branch 2 can be completed.
Is there any other solution to complete this kind of process?
Thank you and regards,
Anh
1 Accepted Solution
Avatar
Correct answer by
Level 8
instead of using a gateway and an event recieve, catch the event on the wait operation (so that the event icon is on the corner of the wait operation's icon). That way, the event is listened for only during the time that the wait operation is executing.You draw a route off of the operation, and you draw a route off of the event catch. If the event catch occurs, its route is followed but not the other. Make sense?
http://help.adobe.com/en_US/livecycle/9.0/workbenchHelp/000113.html#1032048
scott
Avatar
Level 8
Is the gateway configured to use OR-WAIT as the control type?
Avatar
Hi Scott,
Thank you for your reply.
I use OR-Wait condition with the branch gate way.
And the branch with the event listenning is always RUNNING after the other branch completes.
Anh
Avatar
Correct answer by
Level 8
scott
Avatar
Thank you for your reply, Scott.
Sorry for last week I could not access internet.
Your approach is very promising. I will try it and inform you the result.
Anh
Avatar
Hi Scott,
Your suggestion does work! The operation will be INTERRUPT when the event is received but at the end the process can be COMPLETE.
Thank you very much for your help.
Anh
Avatar
Level 8
Good to hear you got it working!
scott
