I can not run any extensions, I have tried a clean install and still no luck, any ideas?
3.5 JEE version, cfbuilder beta3, winxp pro
org.eclipse.swt.SWTException: Failed to execute runnable (org.eclipse.swt.SWTError: No more handles [Could not detect registered XULRunner to use])
at org.eclipse.swt.SWT.error(SWT.java:3884)
at org.eclipse.swt.SWT.error(SWT.java:3799)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:137)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3885)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3506)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
Caused by: org.eclipse.swt.SWTError: No more handles [Could not detect registered XULRunner to use]
at org.eclipse.swt.SWT.error(SWT.java:3910)
Hi ,
Can you turn off debug output in your coldfusion server and then try to run the extensions.
Evelin Varghese
Adobe ColdFusion Builder Team
Doesn't seem to help as I am still getting an Unhandled Loop Event Exception error:
at org.eclipse.swt.browser.Mozilla.create(Mozilla.java:473)
at org.eclipse.swt.browser.Browser.<init>(Browser.java:119)
at com.adobe.ide.coldfusion.appcodegeneration.runtime.dialogs.HTMLContentDialog.createDialogArea(HTMLContentDialog.java:111)
at org.eclipse.jface.dialogs.TitleAreaDialog.createContents(TitleAreaDialog.java:147)
at com.adobe.ide.coldfusion.appcodegeneration.runtime.dialogs.HTMLContentDialog.createContents(HTMLContentDialog.java:164)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
at org.eclipse.jface.window.Window.open(Window.java:790)
at com.adobe.ide.coldfusion.appcodegeneration.runtime.CFMenuHandler$6.run(CFMenuHandler.java:473)
at org.eclipse.ui.internal.UILockListener.doPendingWork(UILockListener.java:155)
at org.eclipse.ui.internal.UISynchronizer$3.run(UISynchronizer.java:158)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
... 22 more
I am getting closer to the problem. I unchecked the "Use Mozilla Browser" in preferences and now I see the errors complaining about path locations on extensions. I have uninstalled the extensions and reinstall using default webroot path of my server, some work some don't. This has only been a problem since I upgraded to CF9 from an existing CF8 installation.
Ok, I found the cause and solution to this problem. This was caused by the CF9 install script on an existing CF8 installation with an already configured web connector for IIS. When installing CF9 the location of the CFIDE directory was somehow located to c:/insetpub/wwwroot/CFIDE/CFIDE and the existing virtual directory on IIS was also modified (not sure if it was the install script or not). I ended up moving the CFIDE directory and updated [cf9 home]\lib\neo-runtime.xml with new location of CFIDE and then updated the IIS virtual directory location and all my extensions now work. I do find it odd that the extension didn't work even when the CF9 was aware of the path to the CFIDE and only started working when I moved it to the "default".
