Has anyone run across a plug-in or FrameScript that applies the same set of global properties to all anchored frames in a file or book?
I'm working on a legacy document and I need to change all anchored frames to have a 1 pt black rule, right align, have the same width, and be set to Below Current Line.
Bonus points for setting the graphic inside to 0/0 offset.
(ImpGraph does some of this for newly imported graphics, but this is applying changes to existing frames... more of a global S&R operation.)
Art
Hi Art,
This is a really short script (without bonus points). Like this:
Local lvObj lvDoc(ActiveDoc) lvCount(0) lvColor;
Get Object DocObject(lvDoc) Type(Color) Name('Black') NewVar(lvColor);
Set lvObj = lvDoc.FirstGraphicInDoc;
Loop While(lvObj)
If (lvObj.ObjectName = 'AFrame')
Set lvCount = lvCount + 1;
Set lvObj.Pen = FillBlack;
Set lvObj.BorderWidth = 1; // metrics in pt
Set lvObj.Color = lvColor;
Set lvObj.Alignment = AlignRight;
Set lvObj.AnchorType = AnchorBelow;
Set lvObj.Width = 35mm;
EndIf
Did anyone use this script with success? I need to re-align all the graphics in some docs to the left, but not make any other changes. I'm thinking I can use just the alignment command in this script to accomplish this.
