15 Replies Latest reply on Jul 6, 2011 6:15 AM by ogaia
    Cannot Print Multiple Copies of a PDF
      I'm using AR 8.1.2 on Fedora 8 printing through CUPS to a Lexmark C530dn using the Lexmark supplied ppd.
      Everything works fine except that I cannot print more than one copy of a pdf at a time. No matter what number I enter in [Copies] just one appears.
      Any help appreciated.
        • 1. Re: Cannot Print Multiple Copies of a PDF
          Level 1
          Hi Jon,
          This is a known problem with Reader 8.1.2.
          We have the issue noted at our end and we are working on it for the next release.
          Thanks & Regards,
          Rishi
          • 2. Re: Cannot Print Multiple Copies of a PDF
            Level 1
            Thanks Rishi, apologies for flagging a known issue.
            • 3. Re: Cannot Print Multiple Copies of a PDF
              John Jason Jordan
              This thread is over a year old and referred to 8.1.2.
              I am using Adobe Reader 9.1.3 on Jaunty x86_64, installed from Ubuntu repositories via Synaptic. I am printing to a Laserjet 8000DN via ethernet. I have exactly the same problem as the original poster. Regardless of how many copies I specify I get only one copy.
              Looking at the command that Reader is sending I can see why. The command contains "-o Copies = x." I can change x to whatever I want by
              selecting a different number in the GUI (you can't edit the line manually in Reader 9.1). But it still prints only one copy. That is because "-o Copies = x" is not valid lpr syntax. The correct syntax is "-#x." And lpr ignores all commands that it does not understand.
              However, I must have misunderstood something, because I can't believe Adobe released Reader 9.1/Linux with such an obvious and major glitch.
              I hope someone can enlighten me.
              • 4. Re: Cannot Print Multiple Copies of a PDF
                John Jason Jordan Level 1
                I posted the same query as above on a CUPS e-list. I received a reply:
                Adobe really did release software with such an obvious and major glitch.
                FWIW, "-o copies=x" is also valid.  Putting spaces around the "=" is
                not, however.
                Michael Sweet, Senior Printing Systems Engineer
                So now I suppose I need to file a bug report.
                • 5. Re: Cannot Print Multiple Copies of a PDF
                  moleculeye
                  I noticed the same problem. I'm using Ubuntu 9.04 Jaunty (32-bit) and Acrobat 9.1.3 for Linux. Is there no easy way to patch this?
                  It is pretty appalling that they would release something with such a ridiculous bug present. The worst part is that it has not been fixed since Reader 8.x. When should one give up on Adobe products altogether?
                  • 6. Re: Cannot Print Multiple Copies of a PDF
                    shilpi Aggarwal Adobe Employee
                    This issue has been fixed in the 9.2 release of reader.
                    You can download the same from ftp://ftp.adobe.com/pub/adobe/reader/unix/9.x/9.2/enu/
                    Please let us know if it resolves the issue.
                    -Shilpi
                    • 7. Re: Cannot Print Multiple Copies of a PDF
                      LIS-CoreBiz
                      I have still this issue with Ubuntu 8.04 and Ubuntu 9.04 (32 bit) and Adobe Reader 9.3.1.
                      A fix would be appreciated.
                      Thilo
                      • 8. Re: Cannot Print Multiple Copies of a PDF
                        RishiOberoi10 Level 1
                        Hi Thilo,
                        The issue was fixed with 9.2u.
                        Please check whether you are using the latest version.
                        If the issue still persists, try the following:
                        1) Before launching acroread from the shell, execute the following command at the shell :
                        export ACRO_PRINT_DEBUG=1
                        2) Then launch reader from the shell and print a pdf file.
                        3) On hitting the OK button in the print dialog, the application makes a log of the command sent to the printer.
                        It would start as
                        The FINAL commandLine being sent to the printer : .......
                        Copy the command in your post.
                        Also let us know the ppdf file(driver) used to configure the printer.
                        Rishi
                        • 9. Re: Cannot Print Multiple Copies of a PDF
                          LIS-CoreBiz Level 1
                          Hi Rishi,
                          thanks for your answer!
                          > log of the command sent to the printer. It would start as
                          lpr -P lp18 -o Duplex=None -o InputSlot=Default -o PageRegion=A4 -o
                          PageSize=A4 -o PrinterResolution=FromPrintoutMode -o PrintoutMode=Normal -# 2
                          The ppd of this printer is attached.
                          I did one more test with another printer (lp20, ppd attached). I could print
                          the same document 2 times. So it seems that it depends on the printer if
                          multiple copies works or not.
                          Thilo
                          lp18.ppd
                          *PPD-Adobe: "4.3"
                          *% For information on using this, and to obtain the required backend
                          *% script, consult http://www.openprinting.org/
                          *% This file is published under the GNU General Public License
                          *% PPD-O-MATIC (3.0.0 or newer) generated this PPD file. It is for use with
                          *% all programs and environments which use PPD files for dealing with
                          *% printer capability information. The printer must be configured with the
                          *% "foomatic-rip" backend filter script of Foomatic 3.0.0 or newer. This
                          *% file and "foomatic-rip" work together to support PPD-controlled printer
                          *% driver option access with arbitrary free software printer drivers and
                          *% printing spoolers.
                          *% To save this file on your disk, wait until the download has completed
                          *% (the animation of the browser logo must stop) and then use the
                          *% "Save as..." command in the "File" menu of your browser or in the
                          *% pop-up manu when you click on this document with the right mouse button.
                          *% DO NOT cut and paste this file into an editor with your mouse. This can
                          *% introduce additional line breaks which lead to unexpected results.
                          *% You may save this file as 'HP-LaserJet_M1522nf_MFP-pxlmono.ppd'
                          *FormatVersion: "4.3"
                          *FileVersion:   "1.1"
                          *LanguageVersion: English
                          *LanguageEncoding: ISOLatin1
                          *PCFileName:    "PXLMONO.PPD"
                          *Manufacturer:  "HP"
                          *Product:       "(LaserJet M1522nf MFP)"
                          *cupsVersion:   1.0
                          *cupsManualCopies: True
                          *cupsModelNumber:  2
                          *cupsFilter:    "application/vnd.cups-postscript 0 foomatic-rip"
                          *%pprRIP:        foomatic-rip other
                          *ModelName:     "HP LaserJet M1522nf MFP"
                          *ShortNickName: "HP LaserJet M1522nf MFP pxlmono"
                          *NickName:      "HP LaserJet M1522nf MFP Foomatic/pxlmono (recommended)"
                          *PSVersion:     "(3010.000) 550"
                          *PSVersion:     "(3010.000) 651"
                          *PSVersion:     "(3010.000) 652"
                          *PSVersion:     "(3010.000) 653"
                          *PSVersion:     "(3010.000) 704"
                          *PSVersion:     "(3010.000) 705"
                          *PSVersion:     "(3010.000) 800"
                          *PSVersion:     "(3010.000) 815"
                          *PSVersion:     "(3010.000) 850"
                          *PSVersion:     "(3010.000) 860"
                          *PSVersion:     "(3010.000) 861"
                          *PSVersion:     "(3010.000) 862"
                          *PSVersion:     "(3010.000) 863"
                          *LanguageLevel: "3"
                          *ColorDevice:   False
                          *DefaultColorSpace: Gray
                          *FileSystem:    False
                          *Throughput:    "1"
                          *LandscapeOrientation: Plus90
                          *TTRasterizer:  Type42
                          *1284DeviceID: "DRV:Dpxlmono,R1,M0,TG;"
                          *driverName pxlmono/pxlmono: ""
                          *driverType G/Ghostscript built-in: ""
                          *driverUrl: "http://www.ghostscript.com/"
                          *driverObsolete: False
                          *DefaultResolution: 1200dpi
                          *VariablePaperSize: False
                          *FoomaticIDs: HP-LaserJet_M1522nf_MFP pxlmono
                          *FoomaticRIPCommandLine: "gs -q -dBATCH -dPARANOIDSAFER -dNOPAUSE%B%A%&&
                          Z -sOutputFile=- - | perl -p -e 'if (! $did) { s/\xc0.\xf8\x26/\x&&
                          c0%E\xf8\x26/ && $did++; }'"
                          *End
                          *OpenGroup: General/General
                          *OpenUI *PrintoutMode/Printout Mode: PickOne
                          *FoomaticRIPOption PrintoutMode: enum Composite A
                          *OrderDependency: 10 AnySetup *PrintoutMode
                          *DefaultPrintoutMode: Normal
                          *PrintoutMode Draft/Draft: "%% FoomaticRIPOptionSetting: PrintoutMode=Draft"
                          *FoomaticRIPOptionSetting PrintoutMode=Draft: "PrinterResolution=300x3&&
                          00dpi ColorModel=Grayscale"
                          *End
                          *PrintoutMode Normal/Normal: "%% FoomaticRIPOptionSetting: PrintoutMode=Normal"
                          *FoomaticRIPOptionSetting PrintoutMode=Normal: "PrinterResolution=600x&&
                          600dpi ColorModel=Grayscale"
                          *End
                          *PrintoutMode High/High Quality: "%% FoomaticRIPOptionSetting: PrintoutMode=High"
                          *FoomaticRIPOptionSetting PrintoutMode=High: "PrinterResolution=1200x1&&
                          200dpi ColorModel=Grayscale"
                          *End
                          *CloseUI: *PrintoutMode
                          *OpenUI *PageSize/Page Size: PickOne
                          *FoomaticRIPOption PageSize: enum CmdLine A
                          *OrderDependency: 100 AnySetup *PageSize
                          *DefaultPageSize: A4
                          *PageSize Letter/US Letter: "%% FoomaticRIPOptionSetting: PageSize=Letter"
                          *FoomaticRIPOptionSetting PageSize=Letter: " -dDEVICEWIDTHPOINTS=612 -&&
                          dDEVICEHEIGHTPOINTS=792"
                          *End
                          *PageSize A4/A4: "%% FoomaticRIPOptionSetting: PageSize=A4"
                          *FoomaticRIPOptionSetting PageSize=A4: " -dDEVICEWIDTHPOINTS=595 -dDEV&&
                          ICEHEIGHTPOINTS=842"
                          *End
                          *PageSize 11x17/11x17: "%% FoomaticRIPOptionSetting: PageSize=11x17"
                          *FoomaticRIPOptionSetting PageSize=11x17: " -dDEVICEWIDTHPOINTS=792 -d&&
                          DEVICEHEIGHTPOINTS=1224"
                          *End
                          *PageSize A3/A3: "%% FoomaticRIPOptionSetting: PageSize=A3"
                          *FoomaticRIPOptionSetting PageSize=A3: " -dDEVICEWIDTHPOINTS=842 -dDEV&&
                          ICEHEIGHTPOINTS=1191"
                          *End
                          *PageSize A5/A5: "%% FoomaticRIPOptionSetting: PageSize=A5"
                          *FoomaticRIPOptionSetting PageSize=A5: " -dDEVICEWIDTHPOINTS=421 -dDEV&&
                          ICEHEIGHTPOINTS=595"
                          *End
                          *PageSize B5/B5 (JIS): "%% FoomaticRIPOptionSetting: PageSize=B5"
                          *FoomaticRIPOptionSetting PageSize=B5: " -dDEVICEWIDTHPOINTS=516 -dDEV&&
                          ICEHEIGHTPOINTS=729"
                          *End
                          *PageSize Env10/Envelope #10: "%% FoomaticRIPOptionSetting: PageSize=Env10"
                          *FoomaticRIPOptionSetting PageSize=Env10: " -dDEVICEWIDTHPOINTS=297 -d&&
                          DEVICEHEIGHTPOINTS=684"
                          *End
                          *PageSize EnvC5/Envelope C5: "%% FoomaticRIPOptionSetting: PageSize=EnvC5"
                          *FoomaticRIPOptionSetting PageSize=EnvC5: " -dDEVICEWIDTHPOINTS=459 -d&&
                          DEVICEHEIGHTPOINTS=649"
                          *End
                          *PageSize EnvDL/Envelope DL: "%% FoomaticRIPOptionSetting: PageSize=EnvDL"
                          *FoomaticRIPOptionSetting PageSize=EnvDL: " -dDEVICEWIDTHPOINTS=312 -d&&
                          DEVICEHEIGHTPOINTS=624"
                          *End
                          *PageSize EnvISOB5/Envelope B5: "%% FoomaticRIPOptionSetting: PageSize=EnvISOB5"
                          *FoomaticRIPOptionSetting PageSize=EnvISOB5: " -dDEVICEWIDTHPOINTS=499&&
                           -dDEVICEHEIGHTPOINTS=709"
                          *End
                          *PageSize EnvMonarch/Envelope Monarch: "%% FoomaticRIPOptionSetting: PageSize=EnvMonarch"
                          *FoomaticRIPOptionSetting PageSize=EnvMonarch: " -dDEVICEWIDTHPOINTS=2&&
                          79 -dDEVICEHEIGHTPOINTS=540"
                          *End
                          *PageSize Executive/Executive: "%% FoomaticRIPOptionSetting: PageSize=Executive"
                          *FoomaticRIPOptionSetting PageSize=Executive: " -dDEVICEWIDTHPOINTS=52&&
                          2 -dDEVICEHEIGHTPOINTS=756"
                          *End
                          *PageSize Legal/US Legal: "%% FoomaticRIPOptionSetting: PageSize=Legal"
                          *FoomaticRIPOptionSetting PageSize=Legal: " -dDEVICEWIDTHPOINTS=612 -d&&
                          DEVICEHEIGHTPOINTS=1008"
                          *End
                          *CloseUI: *PageSize
                          *OpenUI *PageRegion: PickOne
                          *OrderDependency: 100 AnySetup *PageRegion
                          *DefaultPageRegion: A4
                          *PageRegion Letter/US Letter: "%% FoomaticRIPOptionSetting: PageSize=Letter"
                          *PageRegion A4/A4: "%% FoomaticRIPOptionSetting: PageSize=A4"
                          *PageRegion 11x17/11x17: "%% FoomaticRIPOptionSetting: PageSize=11x17"
                          *PageRegion A3/A3: "%% FoomaticRIPOptionSetting: PageSize=A3"
                          *PageRegion A5/A5: "%% FoomaticRIPOptionSetting: PageSize=A5"
                          *PageRegion B5/B5 (JIS): "%% FoomaticRIPOptionSetting: PageSize=B5"
                          *PageRegion Env10/Envelope #10: "%% FoomaticRIPOptionSetting: PageSize=Env10"
                          *PageRegion EnvC5/Envelope C5: "%% FoomaticRIPOptionSetting: PageSize=EnvC5"
                          *PageRegion EnvDL/Envelope DL: "%% FoomaticRIPOptionSetting: PageSize=EnvDL"
                          *PageRegion EnvISOB5/Envelope B5: "%% FoomaticRIPOptionSetting: PageSize=EnvISOB5"
                          *PageRegion EnvMonarch/Envelope Monarch: "%% FoomaticRIPOptionSetting: PageSize=EnvMonarch"
                          *PageRegion Executive/Executive: "%% FoomaticRIPOptionSetting: PageSize=Executive"
                          *PageRegion Legal/US Legal: "%% FoomaticRIPOptionSetting: PageSize=Legal"
                          *CloseUI: *PageRegion
                          *DefaultImageableArea: A4
                          *ImageableArea Letter/US Letter: "18 36 594 756"
                          *ImageableArea A4/A4: "18 36 577 806"
                          *ImageableArea 11x17/11x17: "18 36 774 1188"
                          *ImageableArea A3/A3: "18 36 824 1155"
                          *ImageableArea A5/A5: "18 36 403 559"
                          *ImageableArea B5/B5 (JIS): "18 36 498 693"
                          *ImageableArea Env10/Envelope #10: "18 36 279 648"
                          *ImageableArea EnvC5/Envelope C5: "18 36 441 613"
                          *ImageableArea EnvDL/Envelope DL: "18 36 294 588"
                          *ImageableArea EnvISOB5/Envelope B5: "18 36 481 673"
                          *ImageableArea EnvMonarch/Envelope Monarch: "18 36 261 504"
                          *ImageableArea Executive/Executive: "18 36 504 720"
                          *ImageableArea Legal/US Legal: "18 36 594 972"
                          *DefaultPaperDimension: A4
                          *PaperDimension Letter/US Letter: "612 792"
                          *PaperDimension A4/A4: "595 842"
                          *PaperDimension 11x17/11x17: "792 1224"
                          *PaperDimension A3/A3: "842 1191"
                          *PaperDimension A5/A5: "421 595"
                          *PaperDimension B5/B5 (JIS): "516 729"
                          *PaperDimension Env10/Envelope #10: "297 684"
                          *PaperDimension EnvC5/Envelope C5: "459 649"
                          *PaperDimension EnvDL/Envelope DL: "312 624"
                          *PaperDimension EnvISOB5/Envelope B5: "499 709"
                          *PaperDimension EnvMonarch/Envelope Monarch: "279 540"
                          *PaperDimension Executive/Executive: "522 756"
                          *PaperDimension Legal/US Legal: "612 1008"
                          *OpenUI *InputSlot/Media Source: PickOne
                          *FoomaticRIPOption InputSlot: enum CmdLine E
                          *OrderDependency: 100 AnySetup *InputSlot
                          *DefaultInputSlot: Default
                          *InputSlot Default/Printer default: "%% FoomaticRIPOptionSetting: InputSlot=Default"
                          *FoomaticRIPOptionSetting InputSlot=Default: "\x01"
                          *InputSlot Tray1/Tray 1: "%% FoomaticRIPOptionSetting: InputSlot=Tray1"
                          *FoomaticRIPOptionSetting InputSlot=Tray1: "\x03"
                          *InputSlot Tray2/Tray 2: "%% FoomaticRIPOptionSetting: InputSlot=Tray2"
                          *FoomaticRIPOptionSetting InputSlot=Tray2: "\x04"
                          *InputSlot Tray3/Tray 3: "%% FoomaticRIPOptionSetting: InputSlot=Tray3"
                          *FoomaticRIPOptionSetting InputSlot=Tray3: "\x05"
                          *InputSlot Tray4/Tray 4: "%% FoomaticRIPOptionSetting: InputSlot=Tray4"
                          *FoomaticRIPOptionSetting InputSlot=Tray4: "\x06"
                          *InputSlot Tray5/Tray 5: "%% FoomaticRIPOptionSetting: InputSlot=Tray5"
                          *FoomaticRIPOptionSetting InputSlot=Tray5: "\x07"
                          *InputSlot Tray6/Tray 6: "%% FoomaticRIPOptionSetting: InputSlot=Tray6"
                          *FoomaticRIPOptionSetting InputSlot=Tray6: "\x08"
                          *InputSlot Tray7/Tray 7: "%% FoomaticRIPOptionSetting: InputSlot=Tray7"
                          *FoomaticRIPOptionSetting InputSlot=Tray7: "\x09"
                          *InputSlot Manual/Manual Feeder: "%% FoomaticRIPOptionSetting: InputSlot=Manual"
                          *FoomaticRIPOptionSetting InputSlot=Manual: "\x02"
                          *CloseUI: *InputSlot
                          *OpenUI *Duplex/Double-Sided printing: PickOne
                          *FoomaticRIPOption Duplex: enum CmdLine A
                          *OrderDependency: 100 AnySetup *Duplex
                          *DefaultDuplex: None
                          *Duplex DuplexNoTumble/On (Flip on Long Edge): "%% FoomaticRIPOptionSetting: Duplex=DuplexNoTumble"
                          *FoomaticRIPOptionSetting Duplex=DuplexNoTumble: " -dDuplex"
                          *Duplex DuplexTumble/On (Flip on Short Edge): "%% FoomaticRIPOptionSetting: Duplex=DuplexTumble"
                          *FoomaticRIPOptionSetting Duplex=DuplexTumble: " -dDuplex -dTumble"
                          *Duplex None/Off: "%% FoomaticRIPOptionSetting: Duplex=None"
                          *FoomaticRIPOptionSetting Duplex=None: ""
                          *CloseUI: *Duplex
                          *FoomaticRIPOption GSResolution: enum CmdLine A 100
                          *FoomaticRIPOptionSetting GSResolution=FromPrinterResolution: ""
                          *FoomaticRIPOptionSetting GSResolution=300x300dpi: " -r300x300"
                          *FoomaticRIPOptionSetting GSResolution=600x600dpi: " -r600x600"
                          *FoomaticRIPOptionSetting GSResolution=1200x600dpi: " -r1200x600"
                          *FoomaticRIPOptionSetting GSResolution=1200x1200dpi: " -r1200x1200"
                          *FoomaticRIPOption JCLResolution: enum JCL A 100
                          *FoomaticRIPOptionSetting JCLResolution=FromPrinterResolution: ""
                          *FoomaticRIPOptionSetting JCLResolution=300x300dpi: "SET RESOLUTION=30&&
                          0"
                          *End
                          *FoomaticRIPOptionSetting JCLResolution=600x600dpi: "SET RESOLUTION=60&&
                          0"
                          *End
                          *FoomaticRIPOptionSetting JCLResolution=1200x600dpi: "SET RESOLUTION=1&&
                          200x600"
                          *End
                          *FoomaticRIPOptionSetting JCLResolution=1200x1200dpi: "SET RESOLUTION=&&
                          1200"
                          *End
                          *FoomaticRIPOption ColorModel: enum CmdLine B 100
                          *FoomaticRIPOptionSetting ColorModel=Grayscale: " -sDEVICE=pxlmono"
                          *CloseGroup: General
                          *OpenGroup: PrintoutMode/Printout Mode
                          *OpenUI *PrinterResolution/Resolution: PickOne
                          *FoomaticRIPOption PrinterResolution: enum Composite A
                          *OrderDependency: 99 AnySetup *PrinterResolution
                          *DefaultPrinterResolution: FromPrintoutMode
                          *PrinterResolution FromPrintoutMode/Controlled by 'Printout Mode': "%% FoomaticRIPOptionSetting: PrinterResolution=FromPrintoutMode"
                          *FoomaticRIPOptionSetting PrinterResolution=FromPrintoutMode: ""
                          *PrinterResolution 300x300dpi/300 DPI: "%% FoomaticRIPOptionSetting: PrinterResolution=300x300dpi"
                          *FoomaticRIPOptionSetting PrinterResolution=300x300dpi: "JCLResolution&&
                          =300x300dpi GSResolution=300x300dpi"
                          *End
                          *PrinterResolution 600x600dpi/600 DPI: "%% FoomaticRIPOptionSetting: PrinterResolution=600x600dpi"
                          *FoomaticRIPOptionSetting PrinterResolution=600x600dpi: "JCLResolution&&
                          =600x600dpi GSResolution=600x600dpi"
                          *End
                          *PrinterResolution 1200x1200dpi/1200 DPI: "%% FoomaticRIPOptionSetting: PrinterResolution=1200x1200dpi"
                          *FoomaticRIPOptionSetting PrinterResolution=1200x1200dpi: "JCLResoluti&&
                          on=1200x1200dpi GSResolution=1200x1200dpi"
                          *End
                          *CloseUI: *PrinterResolution
                          *CloseGroup: PrintoutMode
                          *% Generic boilerplate PPD stuff as standard PostScript fonts and so on
                          *DefaultFont: Courier
                          *Font AvantGarde-Book: Standard "(001.006S)" Standard ROM
                          *Font AvantGarde-BookOblique: Standard "(001.006S)" Standard ROM
                          *Font AvantGarde-Demi: Standard "(001.007S)" Standard ROM
                          *Font AvantGarde-DemiOblique: Standard "(001.007S)" Standard ROM
                          *Font Bookman-Demi: Standard "(001.004S)" Standard ROM
                          *Font Bookman-DemiItalic: Standard "(001.004S)" Standard ROM
                          *Font Bookman-Light: Standard "(001.004S)" Standard ROM
                          *Font Bookman-LightItalic: Standard "(001.004S)" Standard ROM
                          *Font Courier: Standard "(002.004S)" Standard ROM
                          *Font Courier-Bold: Standard "(002.004S)" Standard ROM
                          *Font Courier-BoldOblique: Standard "(002.004S)" Standard ROM
                          *Font Courier-Oblique: Standard "(002.004S)" Standard ROM
                          *Font Helvetica: Standard "(001.006S)" Standard ROM
                          *Font Helvetica-Bold: Standard "(001.007S)" Standard ROM
                          *Font Helvetica-BoldOblique: Standard "(001.007S)" Standard ROM
                          *Font Helvetica-Narrow: Standard "(001.006S)" Standard ROM
                          *Font Helvetica-Narrow-Bold: Standard "(001.007S)" Standard ROM
                          *Font Helvetica-Narrow-BoldOblique: Standard "(001.007S)" Standard ROM
                          *Font Helvetica-Narrow-Oblique: Standard "(001.006S)" Standard ROM
                          *Font Helvetica-Oblique: Standard "(001.006S)" Standard ROM
                          *Font NewCenturySchlbk-Bold: Standard "(001.009S)" Standard ROM
                          *Font NewCenturySchlbk-BoldItalic: Standard "(001.007S)" Standard ROM
                          *Font NewCenturySchlbk-Italic: Standard "(001.006S)" Standard ROM
                          *Font NewCenturySchlbk-Roman: Standard "(001.007S)" Standard ROM
                          *Font Palatino-Bold: Standard "(001.005S)" Standard ROM
                          *Font Palatino-BoldItalic: Standard "(001.005S)" Standard ROM
                          *Font Palatino-Italic: Standard "(001.005S)" Standard ROM
                          *Font Palatino-Roman: Standard "(001.005S)" Standard ROM
                          *Font Symbol: Special "(001.007S)" Special ROM
                          *Font Times-Bold: Standard "(001.007S)" Standard ROM
                          *Font Times-BoldItalic: Standard "(001.009S)" Standard ROM
                          *Font Times-Italic: Standard "(001.007S)" Standard ROM
                          *Font Times-Roman: Standard "(001.007S)" Standard ROM
                          *Font ZapfChancery-MediumItalic: Standard "(001.007S)" Standard ROM
                          *Font ZapfDingbats: Special "(001.004S)" Standard ROM
                          lp20.ppd
                          *PPD-Adobe: "4.3"
                          *% You may save this file as 'HP-LaserJet_4000-hpijs.ppd'
                          *FileVersion:   "1.1"
                          *PCFileName:    "HPIJS.PPD"
                          *Manufacturer:  "HP"
                          *Product:       "(HP LaserJet 4000 Series)"
                          *cupsVersion:   1.0
                          *cupsModelNumber:  2
                          *ModelName:     "HP LaserJet 4000"
                          *ShortNickName: "HP LaserJet 4000 hpijs"
                          *NickName:      "HP LaserJet 4000 Foomatic/hpijs - HPLIP 1.7.3"
                          *LanguageLevel: "3"
                          *ColorDevice:   False
                          *FileSystem:    False
                          *Throughput:    "1"
                          *1284DeviceID: "MFG:Hewlett-Packard;MDL:HP LaserJet 4000 Series;CMD:PJL,MLC,PCL,PCLXL,POSTSCRIPT;DES:Hewlett-Packard LaserJet 4000 Series;DRV:Dhpijs,R0,M1,F1,Sv,TI,X600,Y600,C0,t90,l90,g100,p100,s70;"
                          *driverName hpijs/hpijs - HP's IJS driver for most of their non-PostScript printers: ""
                          *driverType I/IJS: ""
                          *driverUrl: "http://hplip.sourceforge.net/"
                          *driverSupplier: "Hewlett-Packard"
                          *driverManufacturerSupplied: True
                          *driverLicense: "BSD"
                          *driverFreeSoftware: True
                          *driverSupportContactVoluntary: "http://lists.sourceforge.net/mailman/listinfo/hplip-help HPLIP-Help Mailing List"
                          *driverMaxResolution: 600 600
                          *driverColor: False
                          *driverTextSupport: 90
                          *driverLineartSupport: 90
                          *driverGraphicsSupport: 100
                          *driverPhotoSupport: 100
                          *driverRenderingSpeed: 70
                          *DefaultResolution: 600dpi
                          *HWMargins: 18 14.40 18 14.4
                          *VariablePaperSize: True
                          *MaxMediaWidth: 100000
                          *MaxMediaHeight: 100000
                          *NonUIOrderDependency: 105 AnySetup *CustomPageSize
                          *CustomPageSize True: "pop pop pop pop pop
                          %% FoomaticRIPOptionSetting: PageSize=Custom"
                          *End
                          *FoomaticRIPOptionSetting PageSize=Custom: " -dDEVICEWIDTHPOINTS=0 -dD&&
                          EVICEHEIGHTPOINTS=0"
                          *End
                          *ParamCustomPageSize Width: 1 points 36 100000
                          *ParamCustomPageSize Height: 2 points 36 100000
                          *ParamCustomPageSize Orientation: 3 int 0 0
                          *ParamCustomPageSize WidthOffset: 4 points 0 0
                          *ParamCustomPageSize HeightOffset: 5 points 0 0
                          *FoomaticIDs: HP-LaserJet_4000 hpijs
                          *FoomaticRIPCommandLine: "gs -q -dBATCH -dPARANOIDSAFER -dQUIET -dNOPA&&
                          USE -sDEVICE=ijs -sIjsServer=hpijs%A%B%C -dIjsUseOutputFD%Z -sOutputFi&&
                          le=- -"
                          *End
                          *FoomaticRIPOption Model: enum CmdLine A 100
                          *FoomaticRIPOptionSetting Model=HP-LaserJet_4000: " -sDeviceManufactur&&
                          er="HEWLETT-PACKARD" -sDeviceModel="HP LaserJet""
                          *End
                          *FoomaticRIPOption PrintoutMode: enum Composite B
                          *PrintoutMode Draft/Draft (Economy): "%% FoomaticRIPOptionSetting: PrintoutMode=Draft"
                          *FoomaticRIPOptionSetting PrintoutMode=Draft: "Quality=300DraftGraysca&&
                          leK"
                          *End
                          *FoomaticRIPOptionSetting PrintoutMode=Normal: "Quality=300GrayscaleK"
                          *FoomaticRIPOptionSetting PrintoutMode=High: "Quality=600GrayscaleK"
                          *FoomaticRIPOption InputSlot: enum CmdLine C
                          *DefaultInputSlot: Upper
                          *FoomaticRIPOptionSetting InputSlot=Default: ",PS:MediaPosition=7"
                          *InputSlot PhotoTray/Photo Tray: "%% FoomaticRIPOptionSetting: InputSlot=PhotoTray"
                          *FoomaticRIPOptionSetting InputSlot=PhotoTray: ",PS:MediaPosition=6"
                          *InputSlot Upper/Upper Tray: "%% FoomaticRIPOptionSetting: InputSlot=Upper"
                          *FoomaticRIPOptionSetting InputSlot=Upper: ",PS:MediaPosition=1"
                          *InputSlot Lower/Lower Tray: "%% FoomaticRIPOptionSetting: InputSlot=Lower"
                          *FoomaticRIPOptionSetting InputSlot=Lower: ",PS:MediaPosition=4"
                          *InputSlot CDDVDTray/CD or DVD Tray: "%% FoomaticRIPOptionSetting: InputSlot=CDDVDTray"
                          *FoomaticRIPOptionSetting InputSlot=CDDVDTray: ",PS:MediaPosition=14"
                          *InputSlot Envelope/Envelope Feeder: "%% FoomaticRIPOptionSetting: InputSlot=Envelope"
                          *FoomaticRIPOptionSetting InputSlot=Envelope: ",PS:MediaPosition=3"
                          *InputSlot LargeCapacity/Large Capacity Tray: "%% FoomaticRIPOptionSetting: InputSlot=LargeCapacity"
                          *FoomaticRIPOptionSetting InputSlot=LargeCapacity: ",PS:MediaPosition=&&
                          5"
                          *End
                          *FoomaticRIPOptionSetting InputSlot=Manual: ",PS:MediaPosition=2"
                          *InputSlot MPTray/Multi Purpose Tray: "%% FoomaticRIPOptionSetting: InputSlot=MPTray"
                          *FoomaticRIPOptionSetting InputSlot=MPTray: ",PS:MediaPosition=8"
                          *OrderDependency: 105 AnySetup *PageSize
                          *PageSize Letter/Letter: "%% FoomaticRIPOptionSetting: PageSize=Letter"
                          *End
                          *End
                          *PageSize Photo/Photo or 4x6 inch index card: "%% FoomaticRIPOptionSetting: PageSize=Photo"
                          *FoomaticRIPOptionSetting PageSize=Photo: " -dDEVICEWIDTHPOINTS=288 -d&&
                          DEVICEHEIGHTPOINTS=432"
                          *End
                          *PageSize Photo5x7/Photo or 5x7 inch index card: "%% FoomaticRIPOptionSetting: PageSize=Photo5x7"
                          *FoomaticRIPOptionSetting PageSize=Photo5x7: " -dDEVICEWIDTHPOINTS=360&&
                           -dDEVICEHEIGHTPOINTS=504"
                          *End
                          *PageSize 3x5/3x5 inch index card: "%% FoomaticRIPOptionSetting: PageSize=3x5"
                          *FoomaticRIPOptionSetting PageSize=3x5: " -dDEVICEWIDTHPOINTS=216 -dDE&&
                          VICEHEIGHTPOINTS=360"
                          *End
                          *PageSize 5x8/5x8 inch index card: "%% FoomaticRIPOptionSetting: PageSize=5x8"
                          *FoomaticRIPOptionSetting PageSize=5x8: " -dDEVICEWIDTHPOINTS=360 -dDE&&
                          VICEHEIGHTPOINTS=576"
                          *End
                          *FoomaticRIPOptionSetting PageSize=A5: " -dDEVICEWIDTHPOINTS=420 -dDEV&&
                          *End
                          *PageSize A6/A6: "%% FoomaticRIPOptionSetting: PageSize=A6"
                          *FoomaticRIPOptionSetting PageSize=A6: " -dDEVICEWIDTHPOINTS=297 -dDEV&&
                          ICEHEIGHTPOINTS=420"
                          *End
                          *PageSize B5JIS/B5 (JIS): "%% FoomaticRIPOptionSetting: PageSize=B5JIS"
                          *FoomaticRIPOptionSetting PageSize=B5JIS: " -dDEVICEWIDTHPOINTS=516 -d&&
                          DEVICEHEIGHTPOINTS=729"
                          *End
                          *PageSize CDDVD80/CD or DVD 80 mm: "%% FoomaticRIPOptionSetting: PageSize=CDDVD80"
                          *FoomaticRIPOptionSetting PageSize=CDDVD80: " -dDEVICEWIDTHPOINTS=237 &&
                          -dDEVICEHEIGHTPOINTS=237"
                          *End
                          *PageSize CDDVD120/CD or DVD 120 mm: "%% FoomaticRIPOptionSetting: PageSize=CDDVD120"
                          *FoomaticRIPOptionSetting PageSize=CDDVD120: " -dDEVICEWIDTHPOINTS=360&&
                           -dDEVICEHEIGHTPOINTS=360"
                          *End
                          *End
                          *End
                          *PageSize EnvC6/Envelope C6: "%% FoomaticRIPOptionSetting: PageSize=EnvC6"
                          *FoomaticRIPOptionSetting PageSize=EnvC6: " -dDEVICEWIDTHPOINTS=323 -d&&
                          DEVICEHEIGHTPOINTS=459"
                          *End
                          *End
                          *End
                          *End
                          *End
                          *PageSize FLSA/American Foolscap: "%% FoomaticRIPOptionSetting: PageSize=FLSA"
                          *FoomaticRIPOptionSetting PageSize=FLSA: " -dDEVICEWIDTHPOINTS=612 -dD&&
                          EVICEHEIGHTPOINTS=936"
                          *End
                          *PageSize Hagaki/Hagaki: "%% FoomaticRIPOptionSetting: PageSize=Hagaki"
                          *FoomaticRIPOptionSetting PageSize=Hagaki: " -dDEVICEWIDTHPOINTS=283 -&&
                          dDEVICEHEIGHTPOINTS=420"
                          *End
                          *PageSize Legal/Legal: "%% FoomaticRIPOptionSetting: PageSize=Legal"
                          *End
                          *PageSize Oufuku/Oufuku-Hagaki: "%% FoomaticRIPOptionSetting: PageSize=Oufuku"
                          *FoomaticRIPOptionSetting PageSize=Oufuku: " -dDEVICEWIDTHPOINTS=420 -&&
                          dDEVICEHEIGHTPOINTS=567"
                          *End
                          *PageSize w558h774/16K: "%% FoomaticRIPOptionSetting: PageSize=w558h774"
                          *FoomaticRIPOptionSetting PageSize=w558h774: " -dDEVICEWIDTHPOINTS=558&&
                           -dDEVICEHEIGHTPOINTS=774"
                          *End
                          *PageSize w612h935/Executive (JIS): "%% FoomaticRIPOptionSetting: PageSize=w612h935"
                          *FoomaticRIPOptionSetting PageSize=w612h935: " -dDEVICEWIDTHPOINTS=612&&
                           -dDEVICEHEIGHTPOINTS=935"
                          *End
                          *CloseUI: *PageSize
                          *OrderDependency: 105 AnySetup *PageRegion
                          *PageRegion Letter/Letter: "%% FoomaticRIPOptionSetting: PageSize=Letter"
                          *PageRegion Photo/Photo or 4x6 inch index card: "%% FoomaticRIPOptionSetting: PageSize=Photo"
                          *PageRegion Photo5x7/Photo or 5x7 inch index card: "%% FoomaticRIPOptionSetting: PageSize=Photo5x7"
                          *PageRegion 3x5/3x5 inch index card: "%% FoomaticRIPOptionSetting: PageSize=3x5"
                          *PageRegion 5x8/5x8 inch index card: "%% FoomaticRIPOptionSetting: PageSize=5x8"
                          *PageRegion A6/A6: "%% FoomaticRIPOptionSetting: PageSize=A6"
                          *PageRegion B5JIS/B5 (JIS): "%% FoomaticRIPOptionSetting: PageSize=B5JIS"
                          *PageRegion CDDVD80/CD or DVD 80 mm: "%% FoomaticRIPOptionSetting: PageSize=CDDVD80"
                          *PageRegion CDDVD120/CD or DVD 120 mm: "%% FoomaticRIPOptionSetting: PageSize=CDDVD120"
                          *PageRegion EnvC6/Envelope C6: "%% FoomaticRIPOptionSetting: PageSize=EnvC6"
                          *PageRegion FLSA/American Foolscap: "%% FoomaticRIPOptionSetting: PageSize=FLSA"
                          *PageRegion Hagaki/Hagaki: "%% FoomaticRIPOptionSetting: PageSize=Hagaki"
                          *PageRegion Legal/Legal: "%% FoomaticRIPOptionSetting: PageSize=Legal"
                          *PageRegion Oufuku/Oufuku-Hagaki: "%% FoomaticRIPOptionSetting: PageSize=Oufuku"
                          *PageRegion w558h774/16K: "%% FoomaticRIPOptionSetting: PageSize=w558h774"
                          *PageRegion w612h935/Executive (JIS): "%% FoomaticRIPOptionSetting: PageSize=w612h935"
                          *ImageableArea Letter/Letter: "18 14.40 594 777.60"
                          *ImageableArea A4/A4: "18 14.40 577 827.60"
                          *ImageableArea Photo/Photo or 4x6 inch index card: "18 14.40 270 417.60"
                          *ImageableArea Photo5x7/Photo or 5x7 inch index card: "18 14.40 342 489.60"
                          *ImageableArea 3x5/3x5 inch index card: "18 14.40 198 345.60"
                          *ImageableArea 5x8/5x8 inch index card: "18 14.40 342 561.60"
                          *ImageableArea A5/A5: "18 14.40 402 580.60"
                          *ImageableArea A6/A6: "18 14.40 279 405.60"
                          *ImageableArea B5JIS/B5 (JIS): "18 14.40 498 714.60"
                          *ImageableArea CDDVD80/CD or DVD 80 mm: "18 14.40 219 222.60"
                          *ImageableArea CDDVD120/CD or DVD 120 mm: "18 14.40 342 345.60"
                          *ImageableArea Env10/Envelope #10: "18 14.40 279 669.60"
                          *ImageableArea EnvC5/Envelope C5: "18 14.40 441 634.60"
                          *ImageableArea EnvC6/Envelope C6: "18 14.40 305 444.60"
                          *ImageableArea EnvDL/Envelope DL: "18 14.40 294 609.60"
                          *ImageableArea EnvISOB5/Envelope B5: "18 14.40 481 694.60"
                          *ImageableArea EnvMonarch/Envelope Monarch: "18 14.40 261 525.60"
                          *ImageableArea Executive/Executive: "18 14.40 504 741.60"
                          *ImageableArea FLSA/American Foolscap: "18 14.40 594 921.60"
                          *ImageableArea Hagaki/Hagaki: "18 14.40 265 405.60"
                          *ImageableArea Legal/Legal: "18 14.40 594 993.60"
                          *ImageableArea Oufuku/Oufuku-Hagaki: "18 14.40 402 552.60"
                          *ImageableArea w558h774/16K: "18 14.40 540 759.60"
                          *ImageableArea w612h935/Executive (JIS): "18 14.40 594 920.60"
                          *PaperDimension Letter/Letter: "612 792"
                          *PaperDimension Photo/Photo or 4x6 inch index card: "288 432"
                          *PaperDimension Photo5x7/Photo or 5x7 inch index card: "360 504"
                          *PaperDimension 3x5/3x5 inch index card: "216 360"
                          *PaperDimension 5x8/5x8 inch index card: "360 576"
                          *PaperDimension A5/A5: "420 595"
                          *PaperDimension A6/A6: "297 420"
                          *PaperDimension B5JIS/B5 (JIS): "516 729"
                          *PaperDimension CDDVD80/CD or DVD 80 mm: "237 237"
                          *PaperDimension CDDVD120/CD or DVD 120 mm: "360 360"
                          *PaperDimension EnvC6/Envelope C6: "323 459"
                          *PaperDimension FLSA/American Foolscap: "612 936"
                          *PaperDimension Hagaki/Hagaki: "283 420"
                          *PaperDimension Legal/Legal: "612 1008"
                          *PaperDimension Oufuku/Oufuku-Hagaki: "420 567"
                          *PaperDimension w558h774/16K: "558 774"
                          *PaperDimension w612h935/Executive (JIS): "612 935"
                          *OpenUI *Duplex/Double-Sided Printing: PickOne
                          *OrderDependency: 120 AnySetup *Duplex
                          *Duplex DuplexNoTumble/Long Edge (Standard): "%% FoomaticRIPOptionSetting: Duplex=DuplexNoTumble"
                          *FoomaticRIPOptionSetting Duplex=DuplexNoTumble: " -dDuplex=true -dTum&&
                          ble=false"
                          *End
                          *Duplex DuplexTumble/Short Edge (Flip): "%% FoomaticRIPOptionSetting: Duplex=DuplexTumble"
                          *FoomaticRIPOptionSetting Duplex=DuplexTumble: " -dDuplex=true -dTumbl&&
                          e=true"
                          *End
                          *FoomaticRIPOptionSetting Duplex=None: " -dDuplex=false"
                          *CloseUI: *Duplex
                          *OpenUI *Quality/Resolution, Quality, Ink Type, Media Type: PickOne
                          *FoomaticRIPOption Quality: enum CmdLine B
                          *OrderDependency: 100 AnySetup *Quality
                          *DefaultQuality: FromPrintoutMode
                          *Quality FromPrintoutMode/Controlled by 'Printout Mode': "%% FoomaticRIPOptionSetting: Quality=@PrintoutMode"
                          *Quality 300DraftGrayscaleK/300 dpi, Draft, Grayscale, Black Cartr.: "%% FoomaticRIPOptionSetting: Quality=300DraftGrayscaleK"
                          *FoomaticRIPOptionSetting Quality=300DraftGrayscaleK: " -r300 -sIjsPar&&
                          ams=Quality:Quality=1,Quality:ColorMode=0,Quality:MediaType=0,Quality:&&
                          PenSet=0"
                          *End
                          *Quality 300GrayscaleK/300 dpi, Grayscale, Black Cartr.: "%% FoomaticRIPOptionSetting: Quality=300GrayscaleK"
                          *FoomaticRIPOptionSetting Quality=300GrayscaleK: " -r300 -sIjsParams=Q&&
                          uality:Quality=0,Quality:ColorMode=0,Quality:MediaType=0,Quality:PenSe&&
                          t=0"
                          *End
                          *Quality 600GrayscaleK/600 dpi, Grayscale, Black Cartr.: "%% FoomaticRIPOptionSetting: Quality=600GrayscaleK"
                          *FoomaticRIPOptionSetting Quality=600GrayscaleK: " -r600 -sIjsParams=Q&&
                          t=0"
                          *End
                          *CloseUI: *Quality
                          • 10. Re: Cannot Print Multiple Copies of a PDF
                            SLES11
                            I upgrade to lasted version (9.3.2) Still  not working (openSUSE11.2, SLED10SP2).
                            How to Fix?
                            Thank you,
                            Sontaya
                            • 11. Re: Cannot Print Multiple Copies of a PDF
                              Hi Sontaya,
                              Could you repeat the steps I mentioned in my previous post and let me know the results.
                              Please let me know how is your printer configured?
                              Also please attach the ppd used to configure the printer.
                              Rishi
                              • 12. Re: Cannot Print Multiple Copies of a PDF
                                SLES11 Level 1
                                Hi Rishi,
                                Thank you for reply. Now it work already. (I reboot)
                                Sontaya
                                http://blog.susethailand.com
                                • 13. Re: Cannot Print Multiple Copies of a PDF
                                  pmbays
                                  I'm using Acrobat 9.4 and still experiencing this same problem (under Windows 7 with an HP Color Laserjet CP2025N). It's fixed by selecting 'collate'.
                                  • 14. Re: Cannot Print Multiple Copies of a PDF
                                    ghdfans2010
                                    Your post really helps me so much. I am new to internet, there are many things I need to learn. This is my first job for ghd company.
                                    • 15. Re: Cannot Print Multiple Copies of a PDF
                                      ogaia Level 1
                                      I'm using Acrobat 9.4 and still experiencing this same problem (under Solaris 10 x86_64). I performed the procedure suggested by Rishi and obtained the following result:
                                      libcups of dlopen failed - ld.so.1: acroread: fatal: libcups.so: open failed: No such file or directory
                                      request id is trans-744 (1 file (s))
                                        The FINAL commandLine Being sent to the printer:
                                      I do not have cups installed on the server (I think there is no version for Solaris). How to fix?
                                      Oswaldo
