Issue with CFQUERY results
Guest
Mar 05, 2010 Mar 05, 2010
Hello,
Im building a data export and trying to build the columns in the export file dynamically by storing and pulling them out of a seperate database table.  My issue is with a column called "COL-1".  Im building the data export as using the method below, then putting the two variables together to create the export..
<cfsavecontent variable="dataheader"><cfoutput query="getColumns">#getColumns.column_nm#|</cfoutput><cfoutput>#chr(13)##chr(10)#</cfoutput></cfsavecontent>
<cfsavecontent variable="datarecords">
     <cfoutput query="getData">
          <cfloop query="getColumns">
               <!---  below line is where error occurs --->
               <cfset variables.col_value = '#evaluate("getData." & getColumns.column_nm)#|'>
          </cfloop>
     </cfoutput>
</cfsavecontent>
<cfset variables.data_export = dataheader & datarecords>
Error Occurred While Processing Request
Element COL is undefined in GETDATA.
How do I get CF to evaluate() the entire column name (COL-1)??
Message was edited by: BigFeetBigShoes - reformatted code example.
Advanced techniques
469
Valorous Hero , Mar 05, 2010 Mar 05, 2010
(COL-1)??
You can use array notation instead of evaluate. The basic syntax is
yourQueryName[columnName][rowNumber]
Valorous Hero ,
(COL-1)??
Guest
Mar 08, 2010 Mar 08, 2010
@cfsearching - Thanks a bunch, that did the trick.
Mar 06, 2010 Mar 06, 2010
In addition to the previous answer, you have a logic problem in that you are overwriting your col_val variable each time you go through your loop.
Guest
@Dan - thanks.  In the actual code I have a list append function Im referencing after that statement.  So its there, just not in this example, good looking out though.
Documentation
