PS CS4 - latest
A few times, I've dragged a document window over(on top of) a set of panels (layers,channels, etc). Once I let go of the mouse, the title bar of that window (the draggable bar) is placed behind the panels (I'm in standard screen mode). Most of the time this isn't an issue, and probably because I've never dragged a small enough document window over a panel set for this to be an issue worth asking about (all times before, the document window was wide enough to extend out behind the panel(s), so I was still able to click on the title bar. So, after moving this small window and letting go of the mouse, the title bar is completely hidden behind the panel. I know I can move the panels around and/or minimize the panels, but I'm wondering if there is a setting where you can have your document windows (always on top) of other panels?
If you loose a window behind your panels just hit the tab key which hides all tool bars and panels, drag out your window and hit tab key to make your tools/panels visible again. Panels will always be on top of windows.
