1. Re: Flash exports the movie playback component as separate swf
kglad Mar 7, 2010 8:57 PM (in response to El Gu man)you should have a main swf and a skin.swf. that's normal. upload both, as well as, your html and js files to your server.
2. Re: Flash exports the movie playback component as separate swf
avecessi Mar 8, 2010 6:43 AM (in response to kglad)Hi Klad,
Thanks for the response. Yes, if I were to publish the swf and the html from Flash, then both the movie and the skin appear on the pubslihed html file. However, if I want to insert the movie via Dreamweaver, there are two swf's. Do you know of a trick here?
Best,
Gustavo
3. Re: Flash exports the movie playback component as separate swf
El Gu man Mar 11, 2010 7:46 AM (in response to kglad)Hey Kglad,
Do you know why and how the Flash-published html contains both swf's? (movie and skin). The methods for embedding movie via Dw and Flash are different. I'd prefer using the Dw method for many reasons that have been discussed at great lenght everywhere (http://blog.deconcept.com/swfobject/.).
Gustavo
4. Re: Flash exports the movie playback component as separate swf
kglad Mar 11, 2010 7:59 AM (in response to El Gu man)i'd recommend seeking help on the dreamweaver forum for dreamweaver issues.
you can use swfobject to embed swfs. that's not a problem.
5. Re: Flash exports the movie playback component as separate swf
El Gu man Mar 11, 2010 8:47 AM (in response to kglad)I know I can use swoject, etc. This is not a Dw issue. Goodbye.
