Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
Passing Complex Object into Grid Component
Avatar
Level 2
OK here is what i am trying to do.
I have a grid component, and I wanted to display on the grid,
a list of ship objects. Think of this like a cruise liner.
I am retrieving these objects from a java/hybernate/spring
adapter using remote object, and it works ok. I get back an
arrayCollection, then I build a new array, populatate it with
Actionscript ship objects, which has an embedded port object.
Ship has attributes like Name, id, comments etc. And it has
an embedded homeport object also.
The port, has name, country and comments too.
I can get the object to come back, and its being built
correctly. I have ship objects and each one has its own port
object, I see in the debugger the objects and thier embedded
objects and the embedded object values. So I know the constructor
is working fine. Here is the problem.
I set the dataprovider attribute to match the array of
completed ships, and I can get the grid, to display all the ship
data, but not the port data.
So Here is my code:
<mx:DataGrid id="ShipListDataGrid" width="978"
height="190" dataProvider="{initDG}"
creationComplete="loadAllShips()" selectedIndex="0" >
<mx:columns>
<mx:DataGridColumn headerText="Name"
dataField="name"/>
<mx:DataGridColumn headerText="Class"
dataField="clazz"/>
<mx:DataGridColumn headerText="Comments"
dataField="comments"/>
<mx:DataGridColumn headerText="Port Country"
dataField="port.country" />
</mx:columns>
</mx:DataGrid>
Now the colums name, clazz, comments all work perfectly, as
they are attributes of ship. However, port.country does not work,
it just shows a blank column, even though that is the correct
notation to get to that data field, for the attribute of that ships
port home country. Its just a string, so for the port called miami,
the country is "USA". This does not display.
However if I remove port.country, and only put in port, then
it shows that whats in that column displays as Object : Port.
So it seems that the grid knows theres an object in there.
But not what to do with it?
I have created a masterViewList and a masterDetails
component, and the viewList is the grid, and the details is the
details section of the ship. So there it shows a form, and the form
shows all the details of the ship selected in the list above. Heres
the interesting thing. using a label field, I can change the
selected list item on the grid, and show the ship.port.country in a
label on the bottom, so it can transverse the ship object, but just
not seemingly in the grid.
What can I do? Why does it work with a label field, and not
in the grid? Why will the grid not show an embedded string
attribute for an embedded object, but a label or text box will?
What am I doing wrong?
Avatar
Level 1
You will need to use a label function for this.
For example:
dataField="{calcPortCountry}" />
private function calcPortCountry(item:Object,
col:DataGridColumn):String
return item.port.country;
Avatar
Level 2
Thanks for your reply Jasowill.
Sadly though, this still is not working even though I have
implemented this as you said.
I get nothing back, nothing is in that grid column, and there
is nothing in the debugger either. I have no idea how to track this
down.
Avatar
Level 2
He mistyped the solution. It should be:
labelFunction="calcPortCountry" />
Avatar
Level 2
Ah haaa
That did it. Thanks all.
