I have a watched folder as a start point and I can use the
symbols %F and %E in order to save the output documents in the Result folder.
This is easy.
What I cannot do, is getting in a string variable the same filename in order to use it within the Process:
Is it possible?
I would like to exploit this filename to discriminate the activities that the file have to make...
Thanks you as usual!
Solved! Go to Solution.
Total Likes
You can add a setValue and use the getDocAttribute method to get some attributes about the document variable that contains the file that was dropped.
For example:
/process_data/@tmpString = getDocAttribute(/process_data/@docXML, "basename")
Jasmin
Total Likes
For example:
Jasmin
Total Likes
thank you Jasmin, your answer is correct and now it works!
only I don't understand why my way didn't work...
Instead of a setValue, I used directly a INSERT SQL activity with getDocAttribute(/process_data/@docXML, "basename") as parameter: as is, it didn't work!
As you suggest, if I put a setValue between the Watched folder startpoint and the INSERT SQL activity (now with the populated string as parameter), it works...
Bah!
Thank you again!
Fabio
Total Likes
It could be a bug with the SQL operation.
I think your solution should have worked.
Jasmin
Total Likes
