1. Re: Thawte code signing certificate problem
Joe ... Ward Mar 10, 2010 11:12 AM (in response to Petteri_Paananen)Try the Mac Keychain Access utility.
2. Re: Thawte code signing certificate problem
Petteri_Paananen Mar 10, 2010 12:19 PM (in response to Joe ... Ward) -
3. Re: Thawte code signing certificate problem
Joe ... Ward Mar 10, 2010 1:50 PM (in response to Petteri_Paananen)Well, yes, apparently Keychain Access doesn't let you export the entire certificate chain.
See http://forums.adobe.com/thread/234000 for a post on essentially the same issue.
I haven't tried it, but maybe you can import the certificate into Firefox and then re-exported it with the entire certificate chain. Or do the same with the Java keytool utility. You could also set the ADT command line parameters to access the Mac Keychain directly, but then you couldn't use the built-in Flash/Flex Builder export. Those are the only options I can think of if you can't get help from Thawte.
4. Re: Thawte code signing certificate problem
tzeng Mar 10, 2010 2:47 PM (in response to Joe ... Ward)You can import the certificate in your .p12 file into Firefox. Then export the c
ertificate again to get the full certificate chain.
5. Re: Thawte code signing certificate problem
Petteri_Paananen Mar 11, 2010 9:54 AM (in response to tzeng)Thanks guys! Now it works. I really got it imported to FF and exported back....this is great!
