Is Photoshop Elements 2 compatible with Windows 7 64-bit?
Guest
Mar 10, 2010 Mar 10, 2010
Hello,
I've just ordered a new PC with Windows 7/64bits.
My old Photoshop Elements 2 still works fine with XP and Vista.
What about W7/64 ?
Difficult to get reliable information from Microsoft compatibility website...
Shall I have to buy the last version ?
Thanks for your help.
Z.
Message title was edited by: Brett N
39.0K
There's a reasonable chance that PSE 2 will work on Windows 7, but you may have to use one of the compatibility modes:
http://www.johnrellis.com/psedbtool/photoshop-elements-faq.htm#_Run_in_Vista
Guest
Thanks John, I'll try compatibility mode.
Adobe Employee ,
Mar 11, 2010 Mar 11, 2010
this might also be helpful for system requirements
http://www.adobe.com/products/photoshopelwin/systemreqs/
-garry
Guest
Mar 14, 2010 Mar 14, 2010
Good news ! I've got my new W7/64 PC, and installed Photoshop Elements 2 without any problem
Thanks everybody !
Jun 17, 2011 Jun 17, 2011
I need help also. Just got Windows7 on an HP. Downloaded PSE 2.0. It installed okay but when I try to open the program, I get the following error:
'Could not start Adobe Photoshop because the volume Windows is using for Virtual Memory does not have enough free space, which could lead to stability problems. See Windows Help for information on increasing available Virtual Memory.'
My brand new PC has 6G of RAM. The tech who helped set up the computer said the amount of VM allocated is WAY more than enough.
I'm at a loss and need advice. I LOVE version 2 of Elements and would like to keep it.
Jun 24, 2011 Jun 24, 2011
I like PhotoShop Element 2 as well. Not so long ago, I had installed it on a 64-bit Windows 7 machine with 8 Gigabytes of memory. It installed and worked without any issue. I got a newer replacement machine, also Windows 7 64-bit with 8 Gigabytes of memory, and got the same error you experienced. I was puzzled....the only difference between the two systems was the hard disk size. The working machine had a much smaller hard drive (160 Gigabytes, with about half of it used). The non-working machine had a 500 Gigabyte hard drive with about 400 Gigabtyes free.
The solution I found was to make a permanent swap file for the system. Go into system properties and click the Avanced System Settings. Display the Advanced tab. In the Performance box, click Settings. Display the Advanced tab. In the Virtual memory box, click Change. Unmark the option to automatically manage the paging file size. Mark the optio to for a Custom size. Enter an initial and maximum size. I put in 8142 and 12213. Click Set. (This is important...don't skip this step!) Then click OK. Re-boot your machine, and you should be good to go with PhotoShop Elements 2.
Steve
Adobe Employee ,
Sep 21, 2012 Sep 21, 2012
The error mentioned here has nothing to do with RAM. Generally, this error appears because the free hard disk space is less than the settings for the paging file (virtual memory - hard drive space set aside for use by the OS when RAM runs out). This can also result due to a conflict of Photoshop Elements' own virtual memory (scratch disk) attempting to overlap the same area because there isn't enough hard drive space for both. Regardless of what the OS or PSE are doing, they grab a set amount of space when launched. This space is not filled, but reserved (but it might as well be filled because nothing else can use it). Make sure that at least 15% of your main system hard drive is empty and that the space has been defragmented. Additionally, system security can block access to these spaces. Try disabling security settings (especially the OS UAC).
Apr 16, 2013 Apr 16, 2013
I also run Win 7 64 bit . I tried a wide variety of paging file sizes per your directions.  None worked.  The same error message always appears saying "cannot initialize because scratch disks are full."   Once you click on "OK" it of course terminates the program.    What on earth is the problem ?
I would very much like to run Photoshop Elements 2 on my newwer PC but can't figure out how to do it.
In your case, the problem is you probably have a hard drive over 1TB in size.
(or if your freespace is 1TB or more)
Pse 2 can't see read hard drives over 1TB in size and will generate that message "cannot initialize because scratch disks are full."
Nov 18, 2016 Nov 18, 2016
Thanks, works for win10 as well
