I'm experimenting with the Smart Index Wizard and want to use the Stop List, Always Ignore List and Phrase List to control what keywords it generates. However, I am a little confused about the difference between the Stop List and Always Ignore list. I have read the help, but all it says is that the Stop List is for common words, such as conjunctions, and the Always Ignore list is for keywords. That would be fine, except the default lists contain many of the same words (even though they are disparate files). To add further confusion, the Stop List can only be 512 characters long (as though I’m going to count), which leads me to wonder why you would even both with it? Am I missing some subtle, but crucial differences between these two lists or can I just use the Always Ignore list and ignore the Stop List?
The difference between the two is that one is index related and the other is search related. The Ignore List is used when using the automatic indexing feature of RH and ignores the words or phrases in the text when deciding what index keywords to add. The Stop List is designed to ignore ceratin words that create "noise" when searching for topics. Typically this are short words (e.g. "a", "to", "an" etc.).
Okay, well that is significant. All RoboHelp's manual says is:
You can create a list of words or phrases that the Smart Index wizard ignores. This list is the Always Ignore list.
and
You can create a list of common words (such as a) that the Smart Index wizard ignores. This list is the Stop list.
So you can understand my confusion. Your explanation makes it crystal clear. Thanks, Colum.
