SOLVED
Add rows to and remove rows from a table at runtime question
Avatar
Level 3
I've downloaded an example from Adobe for Adding or Removing a row at runtime.
The example works great, But it only allows you to generate maximum of 7 rows!!!!!
I've tried to change the code but I was unseccessful. Can you help?
Here's the code for the Add button
form1.#subform[0].Add::click - (JavaScript, client)
// nTableLength stores the number of XML elements contained in Table1.
var nTableLength = Table1.nodes.length;
var nNumRow = 0;
for (var nCount = 0; nCount < nTableLength; nCount ++) {
if ((Table1.nodes.item(nCount).className == "subform") & (Table1.nodes.item(nCount).name !== "HeaderRow")) {
  nNumRow = nNumRow + 1;
if (nNumRow == 7) {
xfa.host.messageBox("The maximum allowable number of rows is 7. You cannot add any more rows.", "Warning", 3);
else {
Table1.Row1.instanceManager.addInstance(1);
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
Take a look at the field 'items' it may be defined with a max number rows as depicted by the subform 'detail', below.
Steve
Avatar
Correct answer by
Steve
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
