with the list of languages you have given, RH is out of the
race; it works only with languages using the Western character
set..
As you didn't tell us about your output format, I can only
relate a way for compiled HTML help. Our procedure looks like this:
1. Finish your project in your source language.
2. Give all the HTML files - and, depending on the
translator's technical aptitude, possibly the table of contents
(.hhc) and index (.hhk), too.
3. Make a complete copy of your project in the source
language.
4. Copy the translated files into the new project.
5. Modify the copy's project file (.hhp) using HTML Help
Workshop or FAR to set language, font sets and character sets.
6. Compile the translated project, again using HTML Help
Workshop or FAR.
This procedure works quite well, although you have to do some
thorough checking, especially when using double-byte languages.
One more note: in order for everything to work correctly,
you'll have to do the final compilation on a machine running a
windows version of the desired target language. Mulit-language
windows works most of the time, but not in every case.
Regards
---Dirk Bock
