1. Re: After Effects error: There was an error processing the PDF document.
Todd_Kopriva Mar 15, 2010 3:37 PM (in response to Sproketzz)Here's a shot in the dark:
Is this Illustrator file on another disk drive?
I ask this only because the one other time when I recall seeing this error, it was resolved by moving the Illustrator file to the local disk that the project file was on.
2. Re: After Effects error: There was an error processing the PDF document.
Sproketzz Mar 15, 2010 3:42 PM (in response to Todd_Kopriva)All the project files are on an internal RAID volume inside the MacPro.
The RAID volume isn't having any problems and the other project files seem fine.
Including rendered out quicktime clips. They play fine.
3. Re: After Effects error: There was an error processing the PDF document.
Mylenium Mar 16, 2010 12:30 AM (in response to Sproketzz)This is an issue with AI and ultimately therefore also the AI routines that AE shares to access such files. Has been there forever and neither the AI people nor the AE team seem to be able to fix it in a consistent manner. Simply save a copy of the file from AI, then use Replace Footage instead of reload or at least always fully reload the AE project.
Mylenium
