Locked
<flexunit:TestRunnerBase >problem
Mar 16, 2010 Mar 16, 2010
This is the  code I have written for testing in flexcover
<?xml version="1.0" encoding="utf-8"?>
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
    xmlns:flexunit="http://www.adobe.com/2009/flexUnitUIRunner"
                creationComplete="runMe()" >
    <mx:Script>
        <![CDATA[
            import mouli.UIListener;
     import myComponents.Greeter;
     import org.flexunit.runner.FlexUnitCore;
     import org.flexunit.listeners.UIListener;
     //import flexunit.runner.BaseTestRunner;
     //import flexunit.flexui.TestRunnerBase;
     //import com.adobe.cairngorm.control.FrontController;
     private var core:FlexUnitCore;
     public function runMe():void {
          core = new FlexUnitCore();
          core.addListener(new UIListener(uiListener));
          core.run( myComponents.Greeter );
    </mx:Script>
<flexunit:BaseTestRunner id="uiListener" width="100%" height="100%" />
</mx:Application>
And the error is at  line 26 .. and it is like this
Could not resolve  <flexunit:TestRunnerBase> to a component implementation.         TestFlexcover/src           TestProject.mxml            line 26   1268801906106  25
i am breaking my head on this please help me
FlexUnit
7.8K
Advocate , Mar 17, 2010 Mar 17, 2010
Change the MXML in your file to this instead
    <flexUnit:TestRunnerBase id="uiListener"
Just TestRunnerBase versus BaseTestRunner. Just as an FYI, what is really happening here is that we are instantiating the UI which was originally written for FlexUnit .9. It is then wrapper in our UIListener, which you are doing correctly, to adapt it. Then it is used as a listener.
In the next release or so of FlexUnit this will become easier as this UI is phased out i
Advocate ,
In the next release or so of FlexUnit this will become easier as this UI is phased out in favor of a simpler model.
Mike
Thanks Mike it is working absolutely fine
with regards
aditya
Mar 22, 2010 Mar 22, 2010
Hi Mike ,
I need some help on using flexPMD in "Flex Builder 3" without using maven and ant .. and also how to use and write rules in flexPMD ...
with regards
aditya
Advocate ,
Apr 15, 2010 Apr 15, 2010
Sorry, but I don't know enough about PMD to help you
Thats k
Nov 17, 2010 Nov 17, 2010
I am also getting this same error.  Using FlexBuilder3 (3.4.1 SDK).
Here is my code:
<mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml"
                        xmlns:adobe="http://www.adobe.com/2009/flexUnitUIRunner"
                        layout="absolute" creationComplete="init()">
    <mx:Script>
        <![CDATA[
            import flexUnitTests.TestSuite;
            public function init():void {
                core.run(TestSuite.ampTestSuite);
    </mx:Script>
    <adobe:TestRunnerBase id="uiListener" width="100%" height="100%"  />
</mx:WindowedApplication>
This is the error:  Could not resolve <adobe:TestRunnerBase> to a component implementation.
Roy P.
Mar 18, 2010 Mar 18, 2010
I still have the same problem. "Could not resolve <...TestRunnerBase>. Downloaded the FlexUnit4TurnkeyRC1, running it through FlashDevelop unsing flex framework 4..0.0. Some help please.
Advocate ,
Mar 19, 2010 Mar 19, 2010
Post your code so we can help you.
I am guessing that your namespace on the top of the file either doesn't point to the correct one for the library or isn't matching the tag but I won't know until I see it.
Mike
I have downloaded the FlexUnit Turnkey RC1 and using it as is, without any changes. I run into a lot of problems, mainly the one stated above. However, I have been able to get it to compile occationally, but then i get another problem. Identifier uiListener is used more than once. I change the name of it and it compiles again, but the problem returns. Please shed some light.
May 29, 2010 May 29, 2010
Thanks you very much
Nov 28, 2010 Nov 28, 2010
to ursaditya :
Compiler can't resolve namespace
you need change it from  "http://www.adobe.com/2009/flexUnitUIRunner"  to  "org.flexunit.flexui.*"
eg find in the begining of your code
and replece with
xmlns:flexUnitUIRunner="org.flexunit.flexui.*"
to Michael Labriola;
if I am correct you Adobe Evangelist and write article flexUnit4 in 360 seconds - shame on you that you can't resolve this problem.
But thanks anyway for article!
I really don't like flash/flex documentation since Adobe bye macromedia.
Advocate ,
First, if you note above I did suggest a namespace problem. Second, if you are using this namespace, what it actually means is that you somehow have a library compiled without the proper namespace or things would have worked as expected. Third, I didn't just write the article, I wrote all of FlexUnit.
Mike
Advocate ,
Also, FlexUnit isn't an Adobe project. It is a community project run and documented purely by volunteers, so please feel free to volunteer to help fix any documentation you feel lacking.
Also, as was noted on some of the other posts with the same question, you can take a look here for some additional knowledge base information:
https://flexunit.tenderapp.com/faqs/known-issues/uilistener-not-found-testrunnerbase-errors-and-othe...
Mike
