I'm new to AS3 and although I can see some good practice and functionality I'm constantly getting stucked and can't yet make things that I would do so easily with AS2 - I almost need to relearn it from scratch!. Still I would appreciate some help and guidance on this...
I made a class that creates a "kind" of menu with data from a XML file and basically what it does when it is called is create a emptyMC (a container), add a childMC (a square) and add another child (a text label). When I create the container I'm trying to add a MouseEvent that can act on each the container instances but all I can get is a MouseEvent on object containing all the added MCs. The code follows.
Can anyone enlight me with this issue or explain what am I doing wrong.
I can't understand well the dynamic parenting with AS3 and the lack of using instance names and dot parenting doesn't help.
Thanks in advance.
Note to Adobe: Previous versions of Flash Help Files and AS reference were by far more helpful than in CS4!
In the timeline:
import assets.myDynMenu;
var theMenu:myDynMenu = new myDynMenu("menu.xml");
stage.addChild(theMenu)
stop();
In the class:
package assets
import flash.display.*;
import flash.events.Event;
import flash.events.MouseEvent;
import flash.text.TextField;
import flash.net.*;
public class myDynMenu extends Sprite {
// INIT EXTERNAL DATA LOAD
public function myDynMenu(theData) {
// LOADS THE MENU DATA FROM PREFORMATTED XML
var loader:URLLoader = new URLLoader();
var url:URLRequest = new URLRequest(theData);
loader.addEventListener(Event.COMPLETE, buildTheMenu);
loader.load(url);
// XML MENU DATA LOAD CHECK - ON COMPLETE BUILD OBJECT AND CHILDREN
public function buildTheMenu(event:Event):void {
var xml:XML = new XML(event.target.data);
for (var i=0; i<xml.menuData.menuItem.length(); i++) {
// ADDS A CONTAINER
var itemContainer:MovieClip = new MovieClip();
itemContainer.name = "menu" + i;
// THE NEXT LINE DOESN'T ACT AS I WISHED?!
// IN THE FUNCTION CALLED I NEED TO CONTROL THIS ITEM AND ITS CHILDREN
itemContainer.addEventListener(MouseEvent.MOUSE_OVER, onMouseOver);
itemContainer.x = 100 * i;
itemContainer.y = 0;
itemContainer.mouseEnabled = true;
itemContainer.mouseChildren = false;
addChild(itemContainer);
// ADDS A CHILD TO CONTAINER (a square)
var itemBase:MovieClip = new MovieClip();
itemBase.graphics.beginFill(xml.menuData.mConfig.mainItemColor);
itemBase.graphics.drawRect(0,0,xml.menuData.mConfig.mainItemW,xml.menuData.mConfig.mainItemH);
itemBase.graphics.endFill();
itemBase.name = "base" + i;
itemBase.mouseEnabled = false;
itemBase.mouseChildren = false;
itemContainer.addChild(itemBase);
// ADDS ANOTHER CHILD TO CONTAINER (a text label)
var theLabel:TextField = new TextField();
theLabel.x = 5;
theLabel.y = 5;
theLabel.selectable = false;
theLabel.mouseEnabled = false;
theLabel.border = true;
theLabel.text = xml.menuData.menuItem.mName;
itemContainer.addChild(theLabel);
// THIS IS THE MOUSE OVER THAT I NEED TO ACT ON EACH itemContainer (AND CHILDREN)
private function onMouseOver(event:MouseEvent):void {
event.stopPropagation();
trace("You are over " + this.name );
use:
package assets
import flash.net.*;
loa
use:
package assets
import flash.net.*;
loader.load(url);
// ADDS A CONTAINER
//// THE NEXT LINE DOESN'T ACT AS I WISHED?!
// IN THE FUNCTION CALLED I NEED TO CONTROL THIS ITEM AND ITS CHILDRENitemContainer.addEventListener(MouseEvent.MOUSE_OVER, onMouseOver);
itemBase.graphics.drawRect(0,0,xml.menuData.mConfig.mainItemW,xml.menuData.mCon fig.mainItemH);
theLabel.x = 5;
theLabel.y = 5;
private function onMouseOver(event:MouseEvent):void {event.stopPropagation();
trace("You are over " + event.currentTarget.name );
Thanks, it works like a charm...
you're welcome.
