Unable to record--shuts down after clicking record button
Mar 18, 2010 Mar 18, 2010
Hi everyone,
Simply put, I'm unable to record in Captivate.  Here's a quick workflow breakdown:
1. Open Captivate
2. Create new project
3. Select application/custom window size
4. Click "record" button on top left of application/window
Once this is done, the recording box disappears, and Captivate vanishes (still running in background).  From there I can open Captivate through my Start menu, but it opens a separate application, not the original.  The only way to close that is by ending the task.
Any ideas?  I recently updated to the newest patch, and don't remember experiencing this before.
Recording
946
LEGEND , Mar 18, 2010 Mar 18, 2010
Hi again
You might try clobbering the settings file.
Close Captivate
Open Windows Explorer
Navigate to the following location:
?:\Documents and Settings\??\Application Data\Adobe\Adobe Captivate
? = Drive letter
?? = Your logged in user name
Delete the captivate_v40.dat file you should find there (or rename it if you are hinky about deleting files)
Restart Captivate
Note that this operation may require you to adjust Windows Explorer so it allows you to view these files. Typically you click Tools > Folder
Hi there
I suppose the first thing to do would be to check if it's something generic to Captivate or if it's instead related to the application you are trying to record using Captivate.
On a fresh restart where Captivate isn't running in this odd mode, are you able to use Captivate to record something such as Windows Notepad without issue? If so, odds are that Captivate doesn't like recording the application you are trying to record. But if you see the same behavior when trying to record Notepad, it's likely a general Captivate issue that needs addressing.
So how does Captivate behave if you try to record something like Windows Notepad?
Additionally, what is your operating system?
Windows XP 32 Bit
Windows XP 64 Bit
Windows Vista 32 Bit
Windows Vista 64 Bit
Windows 7 32 Bit
Windows 7 64 Bit
Cheers... Rick
Helpful and Handy Links
Captivate Wish Form/Bug Reporting Form
Adobe Certified Captivate Training
SorcerStone Blog
Captivate eBooks
Hi Rick,
Thanks for the quick response!
I've tried recording several different programs (all on fresh restarts) with no luck.  Examples include: Word, Notepad, Lotus Notes, Internet Explorer, and Paint.
System info:
Adobe Captivate 4 - v.4.01 Build 1658
Windows: XP, service pack 3
UPDATE:
Oddly enough, it appears that it will record sporadically.  After unsucessfully trying to record Notepad (it kicked me out), I allowed Captivate to stay running in the background.  When I went in to Captivate to pull the build info, my recording had saved.  This appears to work sporadically.
Hi again
Sorry, but I negected to ask another important question. How exactly are you trying to record?
* Manual mode
* Demonstration
* Assessment (Training or Simulation)
* Custom
* Full Motion
There are lots of different options for recording. Something may have changed with one of the modes and you may be unaware of it.
Cheers... Rick
SorcerStone Blog
Captivate eBooks
Hi Rick,
No problem.
I've generally just choose the application, and keep it on the stock settings (Demonstration/custom).  It seems to occur no matter what mode I try.
Thanks again!
Hi again
Close Captivate
? = Drive letter
Restart Captivate
Note that this operation may require you to adjust Windows Explorer so it allows you to view these files. Typically you click Tools > Folder Options > View tab and ensure the Hide extensions for known file types and Hide protected operating system files options aren't enabled.
Once you have performed these steps and restarted Captivate, it should notice that the file is missing and will bake up a fresh one on the fly.
Hopefully once you do that Captivate will begin behaving normally again. (I just wish I could do this as easily with some people and animals I know and love!)
Cheers... Rick
SorcerStone Blog
Captivate eBooks
That did the trick!  Thank you very much Rick!
Help resources
