I'm using RH8 HTML. In trying to open a project I work in virtually every day (about 90 MG compiled), all of a sudden the project won't open; the topics appear in the Topic List, but the main screen is blank and I get a constant hourglass that occasionally stops and gives me a cursor, but only for a few seconds. It becomes an hourglass again, and won't let me do anything. RoboHelp itself opens fine, and I can open other projects. All I've done differently was go out of town for 3 days; could it be mad? In previous versions I've had similar problems and I've had to open the HHP file (I believe), thus losing my TOC. This project has 2,000 topics; rebuilding the TOC by hand just isn't an acceptable workaround. The software has been up for about 30 minutes as I type this, and no sign of opening. Any idea what causes this out of the blue?
Jeff Kersh, PhD
Technical Writer
American HealthTech, Inc.
Hi Jeff.
I'd start by ensuring that you have all the RH8 updates installed. Then rename the project's CPD file and open the project. If that doesn't work, check out this link.
Hi Jeff.
Thanks, Colum. That did the trick! This happens so seldom I can never remember what to do. I guess that's a good thing!
Jeff Kersh, PhD
Technical Writer
